[Mapserver-users] Missing Something
Tyler Mitchell
TMitchell at lignum.com
Fri May 21 18:28:54 EDT 2004
> This is all very helpful, I recompiled it with PROJ4 support but I am
getting
> the error:
> msProcessProjection(): Projection library error. no system list, errno:
2
Did you already have proj4 installed? I assume not. Trying running the
"ldconfig" command once after you installed these new libraries. Does
running "mapserv -v" tell you that proj support is in there now?
> Which I am sure you have all seen before... the /usr/local/share/proj
folder
> has all of the files it should have... and if I run a "proj -V
> +init=epsg:2223" it runs and returns information like it should (I
think) but
> I still get that error... My webserver is running under my user account
which
> has r+w permissions to that folder... Any ideas?
I highly recommend keeping it simple first, but dropping all projection
settings. You only need to specify projection info if you are going to
display your map in a projection that is different than your source data
projection. But in your case, I think you were doing fine on that front.
Including your map file again would help to.
Keep with 'er, you'll get it soon :)
Tyler
