[Mapserver-users] Fill Polygons
Eduardo Spremolla
edspremolla at Antel.com.uy
Thu May 20 11:16:49 EDT 2004
You can define the layer as LINES even if the data are polys.
LALO
El jue, 20-05-2004 a las 09:25, Paul Spencer escribió:
> Note that this makes the entire layer transparent, including polygon
> outlines. If you want solid outlines and tranparent fills, you will
> need two separate layers.
> Paul
> Bart van den Eijnden wrote:
> > Hi,
> > you can use TRANSPARENCY for this, see:
> > http://mapserver.gis.umn.edu/doc40/mapfile-reference.html
> > TRANSPARENCY [integer]
> > Sets the transparency level of all classed pixels for a given layer. The
> > value is a percentage (0-100) where 100 is opaque and 0 is fully
> > transparent.
> > Best regards,
> > Bart
> > On Thu, 20 May 2004 13:19:47 +0200, Scott Ainslie <dmi at webmail.co.za>
> > wrote:
> >> Can I make the fill color of polygons transparent, ie: able to see layers
> >> underneath?
> >> Thanks
> >> Scott
> >> _______________________________________________
> >> Mapserver-users mailing list
> >> Mapserver-users at lists.gis.umn.edu
> >> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Eduardo Spremolla <edspremolla at antel.com.uy>
Antel I+D
