[Mapserver-users] php_mapscript401 doesn't display points
Geoprogetti Informatica
noti at ciaoweb.it
Thu May 20 11:52:19 EDT 2004
Hi all,
I updated my application from php_mapscript366 to php_mapscript401 in
win2000 server (IIS5).
401 version doesn't display point shapefile. When I set the reference to 366
version in my code, the point
shapefile returns in the map. Lines and polygons seem to work fine with both
versions.
This is the mapfile:
MAP
NAME "test"
STATUS ON
#EXTENT 1316000 4034000 2310000 5241000
EXTENT 1552554 4673500 1773000 4929127
SIZE 600 600
FONTSET fontset.txt
SHAPEPATH "shape"
IMAGECOLOR 255 255 255
UNITS METERS
SYMBOLSET symbol.sym
#IMAGETYPE PNG
WEB
HEADER toscana_header.html
TEMPLATE query.phtml
FOOTER toscana_footer.html
MINSCALE 10
MAXSCALE 8500000
IMAGEPATH "C:\inetpub\wwwroot\tmp\"
IMAGEURL "/tmp/"
END
REFERENCE
STATUS ON
IMAGE "ref.gif"
SIZE 120 126
EXTENT 1313238 4072162 2312138 5220403
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
SCALEBAR
LABEL
COLOR 0 0 0
END
STYLE 0
SIZE 100 2
BACKGROUNDCOLOR 200 200 200
COLOR 0 0 0
UNITS METERS
INTERVALS 1
TRANSPARENT FALSE
STATUS TRUE
IMAGECOLOR 255 255 221
END
QUERYMAP
COLOR 255 255 0
STATUS ON
STYLE HILITE
END
LAYER
NAME ""
GROUP "test"
TYPE POINT
STATUS On
DATA 'test'
CLASSITEM 'Name'
TEMPLATE "ttt.html"
CLASS
NAME "pp"
EXPRESSION /./
SYMBOL 'test'
SIZE 12
END
END
END
and this is the symbol.sym file:
SYMBOL
TYPE pixmap
IMAGE images/test.gif
NAME "test"
TRANSPARENT 100
END
Any help appreciated
Thanks
Valerio
