[Mapserver-users] Re: TRANSFORM question
Tyler Mitchell
TMitchell at lignum.com
Thu May 20 17:23:55 EDT 2004
Just noticed you probably meant to change the subject, mapguy. So I'm
reposting this for you.
mapguy <phatsbbnlist at twcny.rr.com> wrote on 05/20/2004 01:55:08 PM:
> A question on TRANSFORM and related matters. ALL files verified as much
> as possible (`gdalinfo`, `ogrinfo` , GIS, etc):
> I have some "init=epsg:26918" (UTM 18N GRS80 NAD83) rasters in a tile
> and some "proj=latlong" ( decimal degree ... derived from UTM NAD 83
> GRS80 I believe the metadata implies) data in a line shapefile. They
> plot perfectly.
> I have "init=epsg:32115" (New York State Plane, Transverse Merc with
> false northings and eastings) rasters in a tile and the same shapefile
> as above, both in its original projection and in a state plane
> conversion using ogr2ogr. Things don't seem so perfect.
> The shape file is roughly 1/4 the size and 150 miles or so SW (3 region
> diameters essentially) of the place and size it should be, i.e.
> surrounding the tiled state plane rasters, and the associated quadrangle
> lines from plotting the tileindex shapefile as a vector layer. Either
> projection of the shape file works if I set the projection parameters
> correctly in the map file. Either disappears if I set the wrong
projection.
> the TRANSFORM doesn't seem to matter (though the online docs mention
> both "ON/OFF" and "TRUE/FALSE" in different places, and I tried both)
> Is there a reasonable explanation as to why these files are plotting
> this way? I mean, do false northings and eastings have to be added as
> PROJECTION block params, or something like that? Does/How does TRANSFORM
> work "on the fly", i.e. is there more to it than NOT putting TRANSFORM
> FALSE/OFF in a layer?
