[Mapserver-users] possible to classify map layer on joined dbf?
Emil Zegers
EZS at DeStraat.NL
Fri May 21 03:16:05 EDT 2004
Hello list,
In my map file I have several shapefile map layers with joins to dbf files.
What I'm trying to do is classify and display such a map layer based on attributes from the joined dbf.
But when I try I get an error message:
msDrawMap(): Image handling error. Failed to draw layer named 'aanleiding'.. <br>
msDBFGetItemIndex(): DBASE file error. Item 'AANLEIDING' not found. <br>
The item 'AANLEIDING' is a field in the external dbf.
Querying the map does show the joined attributes so I suppose on a map layer with a join you can query the joined attributes but you cannot use them to classify and display the layer.
Is this correct? If not, what am I missing and if so, wouldn't this be a nice enhancement?
Part of the map file and template can be found at the end of this message.
Emil
Map file:
LAYER
NAME "aanleiding"
METADATA
wms_title "aanleiding"
END
STATUS ON
TYPE POLYGON
DATA bis_rapv
TOLERANCE 8
LABELITEM rap_code
CLASS
NAME "BIS Aanleiding"
COLOR 0 255 0
OUTLINECOLOR 255 0 0
TEMPLATE "C:\websites\dbf_join\bis_aanleiding.htm"
END
JOIN
TABLE "AANLEIDI.DBF"
TO "RAP_CODE"
NAME "bis_aanleiding_join"
FROM "rap_code"
END
END
Template file:
<p class="red">
rapportcode: [rap_code]
<br>
</p>
<p>
rapportcode: [bis_aanleiding_join_RAP_CODE]
<br>
aanleiding: [bis_aanleiding_join_AANLEIDING]
<br>
</p>
<p class="red">
XCOORD: [XCOORD]
<br>
YCOORD: [YCOORD]
<br>
</p>
______________________________________________________
This message has been checked for all known viruses
