[Mapserver-users] Install help on Win 2000 Server with IIS
Fortin,Nicolas [SteFoy]
nicolas.fortin at ec.gc.ca
Fri May 21 09:45:05 EDT 2004
Hi Ross,
At first sight, your mapserver installation seems ok ... It's the demo that have to be correctly configure.
Try setting debug on in the mapfile like this :
-Add DEBUG TRUE on the first line of the Mapfile
-Add LOG "DEMO.LOG" on the WEB element of the mapfile
Run the application again and see if any usefull information appears in the log file.
Also, it could be a permission issue (about 90% of time...). Like I always tell, try running filemon (http://www.sysinternals.com/ntw2k/source/filemon.shtml) when you call the page and check if you see any ACCESS DENIED message.
I have the demo working well here on Win2k/IIS and MS 4.0.1
Good luck,
Nicolas Fortin
-----Message d'origine-----
De : ross s [mailto:r0ss at shaw.ca]
Envoyé : Friday, May 21, 2004 9:11 AM
À : mapserver-users at lists.gis.umn.edu
Objet : Re: [Mapserver-users] Install help on Win 2000 Server with IIS
I tried the path info mentioned and still no luck. Any other suggestions?
Ross
Correct path to image directory as below:
- Create tmp directory under C:\Inetpub\wwwroot\workshop\
<input type="hidden" name="map_web_imagepath" value="C:\Inetpub\wwwroot\workshop\tmp\">
<input type="hidden" name="map_web_imageurl" value="/workshop/tmp">
OR
- Create tmp directory C:\Inetpub\wwwroot\
<input type="hidden" name="map_web_imagepath" value="C:\Inetpub\wwwroot\tmp\">
Lam.
----- Original Message -----
To: <Mapserver-users at l...>
Sent: Friday, May 21, 2004 10:05 AM
Subject: [Mapserver-users] Install help on Win 2000 Server with IIS
> Hi,
> I feel like a bozo for having to ask this but I am totally lost with
setting up MapServer for IIS - the instructions are not all in one place. I am running Windows 2000 Server with IIS. I followed the install instructions to a "T" but the MapServer demo does not work. This is what I have done
> 1. Copied mapserv.exe to "C:\Inetpub\Scripts"
> 2. Copied directory "Proj" to "C:\"
> 3. Copied the files in directory "lib" to C:\WINNT
> 4. Test MapServer with http://localhost/scripts/mapserv.exe? and I
> receive
the message No query information to decode. QUERY_STRING not set. which is good
> 5. Downloaded A copy of the MapServer Demo and unzipped it into
> 6. Modified the index.html parameters to show my configuration or what
> I
believe is my configuration
> <form name="demo" method="GET" action="\scripts\mapserv.exe"
onSubmit="submit_form()">
> <input type="hidden" name="map"
value="C:\Inetpub\wwwroot\workshop\itasca.map">
> <input type="hidden" name="program" value="\scripts\mapserv.exe">
> <input type="hidden" name="root"
value="C:\Inetpub\wwwroot\workshop">
> <input type="hidden" name="map_web_imagepath" value="\tmp\"> <input
> type="hidden" name="map_web_imageurl" value="\tmp\"> 7. Ran the index
> page and called one of the demos and the map image does
not appear in the resulting page just the little x indicating that it could not find the image
> Anyone have any ideas on what configuration or installation steps I
> missed
or how I can resolve my prolems.
> Or more importantly does anyone have an all encompassing install and
> setup
instructions for IIS?
> Thanks in advance and hope some out there can help.
> Ross
> Mapserver-users mailing list
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Mapserver-users at lists.gis.umn.edu http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
