[Mapserver-users] OGR:ODBC Woes
Chip Hankley
Chip.Hankley at rmtinc.com
Fri May 21 09:54:35 EDT 2004
I'm trying to follow the directions in
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?VirtualSpatialData
I'm using one of the pre-compiled Windows binaries from the MS site.
I've made it all the way to the point where I'm trying to display the
results in MS. When I call the map, I get the following error:
msDrawMap(): Image handling error. Failed to draw layer named
'MyVirtualLayer'.
msOGRFileOpen(): OGR error. Open failed for OGR connection
`virtual.ovf'. File not found or unsupported format.
Here's my output of mapserv -v:
MapServer version 4.0.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
OUTPUT=SWF
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
Anyway, I see that there was a long thread about this error back in
January
(http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0401/msg00452.html)
Does anyone know if this was resolved?
Chip
Outgoing messages, along with any attachments, are scanned for viruses at RMT prior to sending.
NOTICE--This email may contain confidential and privileged information
for the sole use of the intended recipient. Any review or distribution
by others is strictly prohibited. If you are not the intended recipient,
please contact the sender immediately and delete all copies.
