[Mapserver-users] Missing Something
Eric Katherman
vaiod at berloy.com
Fri May 21 14:03:34 EDT 2004
Why doesn't this produce anything, I am a newbie so overlooking something is
very possible. All I get is a 640 480 box the color I have chosen below. The
sewera files are all in the data path .dbf .prj .shp .shx. I used ogrinfo -al
to get the extents from the shx file.
this is the url I am using.
http://localhost/cgi-bin/mapserv40?map=/srv/www/htdocs/mapserver/test.map&mode=map
test.map contents ---
MAP
IMAGETYPE PNG
STATUS ON
EXTENT 382487.530826 833318.888530 497485.329577 1017509.008264
SIZE 640 480
SHAPEPATH "data"
IMAGECOLOR 238 238 238
END
LAYER
NAME sewera
DATA sewera
STATUS DEFAULT
TYPE POLYGON
END
Any ideas would be appreciated...
Thanks,
Eric
