[Mapserver-users] (no subject)
Merrett, Mike
mike.merrett at city.whitehorse.yk.ca
Tue May 25 13:21:46 EDT 2004
Hi:
Here is the map file. I am not sure if it worked before I upgraded
to 4.2b3 (as I didnt find the errorlog until after the upgrade)
If I had to guess I would say that it is looking at the lable information
and trying to decode a symbol out of it but all my lable texts are either
random numbers or some text (i.e. lot numbers and street names)
I didnt know about a GIS Users Group in Prince George - where can I find
details? I am going to the Mapserver Usergroup in Ottawa though - will you
be there?
MAP
debug true
NAME Whitehorse
STATUS ON
SIZE 500 400
# SYMBOLSET "e:\\VariousData\\Devel\\map_test\\etc\\symbols.sym"
extent 485108.508198 6714194.605109 506888.578325 6745540.034837
UNITS METERS
SHAPEPATH "e:\\VariousData\\Devel\\map_test\\data"
FONTSET "e:\\VariousData\\Devel\\map_test\\etc\\fonts.txt"
IMAGECOLOR 255 255 255
IMAGETYPE png24
PROJECTION
## <32608>
"proj=utm"
#"init=epsg:32608"
"ZONE=8"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"north"
"no_defs"
END
# Start of web interface definition
WEB
#MINSCALE 2000000
minscale 5
MAXSCALE 60000000
IMAGEPATH "e:\\VariousData\\Devel\\map_test\\tmp\\"
IMAGEURL "/map_test/tmp/"
log 'gmap.log'
METADATA
"title" "Whitehorse, YT (General)"
"author" "Mike Merrett"
END
END
# Start of reference map
REFERENCE
IMAGE images/City_of_Whitehorse_key.png
6745540.034837
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
SIZE 120 90
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
# COLOR 0 0 89
END
STATUS ON
#template "legend.html"
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 400 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS kilometers
INTERVALS 5
STATUS ON
END
QUERYMAP
STYLE HILITE #selected
COLOR 255 0 0
# status on
END
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE rgba
EXTENSION "png"
END
LAYER
NAME "Cadastre Text"
CONNECTION
"e:\GIS_Claims\gisdata\MapInfo\Cadastre\CAD_text.tab"
CONNECTIONTYPE OGR
METADATA
DESCRIPTION "Cadastre Text"
END
STATUS ON
TYPE annotation
minscale 100
MAXSCALE 5000
STYLEITEM "AUTO"
LABELITEM "TEXT"
CLASS
debug true
LABEL
position auto
PARTIALS true
angle auto
END # end of label
END
END # layer
END
-----Original Message-----
From: Tyler Mitchell [mailto:TMitchell at lignum.com]
Sent: May 25, 2004 10:12 AM
To: Merrett, Mike
Subject: Re: [Mapserver-users] (no subject)
Looks like your symbol definition is wrong. Can you provide the full map
file (I know it's looong) so we can see how your symbols are defined and
what symbol is being used here. Do you think this is a problem with the
auto styling? The symbol being used for that layer appears to be goofy.
This may also be related to the version of mapserver you are using. Did
this work before an upgrade?
p.s. are you coming down to the Northern BC GIS Users Group in Prince
George? If so, I'd love to meet, I'm doing a workshop on MapServer!
mapserver-users-admin at lists.gis.umn.edu wrote on 05/25/2004 09:56:54 AM:
> Hi:
> Can anyone explain the following?
> the Error log file gives the following lines:
> Tue May 25 09:50:17 2004 - getSymbol(): Symbol definition error.
> Parsing error near (KODIAK PLACE):(line 1363)
> Parsing error near (449):(line 1363)
> Ogrinfo gives the following output snippet:
> OGRFeature(CAD_text):7846
> DXF_ (Integer) = 7846
> DXF_ID (Integer) = 7846
> X (Real) = 494272.209545523
> Y (Real) = 6729098.07961854
> OFFSETX (Real) = 0
> OFFSETY (Real) = 0
> HEIGHT (Real) = 6
> SYMBOL (Integer) = 4
> LEVEL (Integer) = 5
> TEXT (String) = KODIAK PLACE
> e00_anno_id (Integer) = 7846
> e00_text_level (Integer) = 5
> e00_anno_name (String) = DXF
> Style = LABEL(t:"KODIAK
PLACE",a:0.000000,s:4.799023g,c:#000000,p:1,f:"")
> POINT (494272.206 6729098.082)
> the layer definition in the map file is
> LAYER
> CONNECTION
> CONNECTIONTYPE OGR
> METADATA
> END
> STATUS ON
> TYPE annotation
> minscale 100
> MAXSCALE 5000
> STYLEITEM "AUTO"
> LABELITEM "TEXT"
> CLASS
> debug true
> LABEL
> position auto
> PARTIALS true
> angle auto
> END # end of label
> END
> END # layer
> I have tried every combination of symbol file -- blank - one known good
> entry -- there are no symbols in the map file --
> what symbol is it looking for?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
