[Mapserver-users] (no subject)
    Merrett, Mike
    mike.merrett at city.whitehorse.yk.ca
    Tue May 25 10:21:46 PDT 2004
Hi:
	Here is the map file.   I am not sure if it worked before I upgraded
to 4.2b3 (as I didnt find the errorlog until after the upgrade)
If I had to guess I would say that it is looking at the lable information
and trying to decode a symbol out of it but all my lable texts are either
random numbers or some text (i.e. lot numbers and street names)
I didnt know about a GIS Users Group in Prince George - where can I find
details?  I am going to the Mapserver Usergroup in Ottawa though - will you
be there?
MAP
	debug true
	NAME Whitehorse
	STATUS ON
	SIZE 500 400
#	SYMBOLSET "e:\\VariousData\\Devel\\map_test\\etc\\symbols.sym"
	extent 485108.508198 6714194.605109 506888.578325 6745540.034837
	UNITS METERS
	SHAPEPATH "e:\\VariousData\\Devel\\map_test\\data"
	FONTSET "e:\\VariousData\\Devel\\map_test\\etc\\fonts.txt"
	IMAGECOLOR 255 255 255
	IMAGETYPE png24
	PROJECTION
			##  <32608>
		"proj=utm"
		#"init=epsg:32608"
		"ZONE=8"
		"ellps=WGS84"
		"datum=WGS84"
		"units=m"
		"north"
		"no_defs"
	END
	# Start of web interface definition
	WEB
		#MINSCALE 2000000
		minscale 5
		MAXSCALE 60000000
		IMAGEPATH "e:\\VariousData\\Devel\\map_test\\tmp\\"
		IMAGEURL "/map_test/tmp/"
		log 'gmap.log'
		METADATA
			"title" "Whitehorse, YT (General)"
			"author" "Mike Merrett"
		END
	END
	# Start of reference map
	REFERENCE
		IMAGE images/City_of_Whitehorse_key.png
6745540.034837
		STATUS ON
		COLOR -1 -1 -1
		OUTLINECOLOR 255 0 0
		SIZE 120 90
	END
	# Start of legend
	LEGEND
		KEYSIZE 18 12
		LABEL
			TYPE BITMAP
			SIZE MEDIUM
		#	COLOR 0 0 89
		END
		STATUS ON
		#template "legend.html"
	END
	# Start of scalebar
	SCALEBAR
		LABEL
			COLOR 0 0 0
			SIZE SMALL
		END
		SIZE 400 5
		COLOR 255 255 255
		BACKGROUNDCOLOR 0 0 0
		OUTLINECOLOR 0 0 0
		UNITS kilometers
		INTERVALS 5
		STATUS ON
	END
	QUERYMAP
		STYLE HILITE   #selected
		COLOR 255 0 0
	 # status on
	END
OUTPUTFORMAT
  NAME png24
  DRIVER "GD/PNG"
  MIMETYPE "image/png"
  IMAGEMODE rgba
  EXTENSION "png"
END
	LAYER
		NAME "Cadastre Text"
		CONNECTION
"e:\GIS_Claims\gisdata\MapInfo\Cadastre\CAD_text.tab"
		CONNECTIONTYPE OGR
		METADATA
			DESCRIPTION	"Cadastre Text"
		END
		STATUS ON
		TYPE annotation
		minscale 100
		MAXSCALE 5000
		STYLEITEM "AUTO"
		LABELITEM "TEXT"
		CLASS
			debug true
			LABEL
				position auto
				PARTIALS true
				angle auto
			END # end of label
		END
	END # layer
END
-----Original Message-----
From: Tyler Mitchell [mailto:TMitchell at lignum.com]
Sent: May 25, 2004 10:12 AM
To: Merrett, Mike
Subject: Re: [Mapserver-users] (no subject)
Looks like your symbol definition is wrong.  Can you provide the full map
file (I know it's looong) so we can see how your symbols are defined and
what symbol is being used here.  Do you think this is a problem with the
auto styling?  The symbol being used for that layer appears to be goofy.
This may also be related to the version of mapserver you are using.  Did
this work before an upgrade?
p.s. are you coming down to the Northern BC GIS Users Group in Prince
George?  If so, I'd love to meet, I'm doing a workshop on MapServer!
mapserver-users-admin at lists.gis.umn.edu wrote on 05/25/2004 09:56:54 AM:
> Hi:
> Can anyone explain the following?
> the Error log file gives the following lines:
>    Tue May 25 09:50:17 2004 - getSymbol(): Symbol definition error.
> Parsing error near (KODIAK PLACE):(line 1363)
> Parsing error near (449):(line 1363)
> Ogrinfo gives the following output snippet:
> OGRFeature(CAD_text):7846
>   DXF_ (Integer) = 7846
>   DXF_ID (Integer) = 7846
>   X (Real) = 494272.209545523
>   Y (Real) = 6729098.07961854
>   OFFSETX (Real) = 0
>   OFFSETY (Real) = 0
>   HEIGHT (Real) = 6
>   SYMBOL (Integer) = 4
>   LEVEL (Integer) = 5
>   TEXT (String) = KODIAK PLACE
>   e00_anno_id (Integer) = 7846
>   e00_text_level (Integer) = 5
>   e00_anno_name (String) = DXF
>   Style = LABEL(t:"KODIAK
PLACE",a:0.000000,s:4.799023g,c:#000000,p:1,f:"")
>   POINT (494272.206 6729098.082)
> the layer definition in the map file is
>    LAYER
>       CONNECTION
>       CONNECTIONTYPE OGR
>       METADATA
>       END
>       STATUS ON
>       TYPE annotation
>       minscale 100
>       MAXSCALE 5000
>       STYLEITEM "AUTO"
>       LABELITEM "TEXT"
>       CLASS
>          debug true
>          LABEL
>             position auto
>             PARTIALS true
>             angle auto
>          END # end of label
>       END
>    END # layer
> I have tried every combination of symbol file -- blank - one known good
> entry -- there are no symbols in the map file --
> what symbol is it looking for?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
