[Mapserver-users] WMS Queries
bartvde at xs4all.nl
Wed May 26 04:02:32 EDT 2004
answers inline. First of all, most info can be found at the Wiki:
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WMSMapserverArcExplorer
> Morning all,
> Yesterday I downloaded installed MapServer 4.0.2 (ms402_png_pg.zip) and
> I've tested it very successfully with the demo and created my own
> sample map file. I'm very impressed with the performance and
> functionality, so well done!
> However, I've now hit a bit of a problem, I'm attempting to connect to
> the WMS using ESRI ArcExplorer 4.01 (Build 630.773) with the
> Interoperability extension (version 1) but I keep getting the following
> error 'Invalid Capabilities File'. I think that the problem is that
> ESRI only support WMS Version 1.1.1 and MapServer 4.0.2 only supports
> WMS Versions upto 1.1.0.
> So my questions are:
> 1. Will or does MapServer 4.2 Beta support WMS version 1.1.1 and when
> will it be released?
Mapserver 4.2 does support WMS 1.1.1. ESRI ArcExplorer does however work
with 1.1.0.
> 2. Is it possible to use MapServer as a WMS client for a WMS that
> requires HTTPS?
Good question. I don't think this will be possible out-of-the-box, but I
could be wrong. I only know of an option to supply a user/password to a
WMS server which is protected by Basic Authentication. See e.g.:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=581
> 3. Is it possible to use MapServer as a WMS client to connect to a WMS
> that requires authentication?
Yes, see answer to no. 2.
Best regards,
Bart
> Many thanks in advance,
> Andrew
> PS
> The Full Error message for ArcExplorer is:
> GetCapabilities Request :
> http://myhost/scripts/mapserv.exe?map=C:\MapServer\workshop\itasca.map&VERSION=1.1.1&WMTVER=1.1.1&SERVICE=WMS&REQUEST=capabilities
> ###### Start to WMS getCapabilities in GetWMSService class version=null
> ************** realVersion is = none
> ************** Version is = null
> This version is not supported
> ******** Exception for WMS:null
> java.lang.NullPointerException .....
> Andrew Haigh
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
