[Mapserver-users] French caracters in querybyattributes
Janeks Kamerovskis
janeks.kamerovskis at silva.lv
Wed May 26 09:14:10 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0000_01C4433C.7A673760
Content-Type: text/plain;
charset="windows-1257"
Content-Transfer-Encoding: 7bit
I have similar problem with Latvian characters but it is connected with
encoding.
First I got not correct display of Latvian characters. That problem I solved
by using so called Rim fonts,
because the similar problem and solution was with ArcView 3.x.
But when I tried to make queries, I found that apparently my current Windoze
encoding does not fully
compatible with older Rim fonts encoding.
I have no problem with strings, that includes long letters, but when I used
soft letters mapserver does
not return any results.
Is there any solution for this problem?
Thanks
Janeks
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of
gheysen.t at skynet.be
Sent: Wednesday, May 26, 2004 11:14 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] French caracters in querybyattributes
Hello,
I have hade some problems with french caracters.
First when I read the results of a query this caracters are not correct. I
have solve this problem by modify the fonts encoding to ISO-8859-1. Thus,
now, I can make a query and read the results correctly.
But, I always have a problem with the caracter '. I make a query to find
the town "Braine l'Alleud" and I always have no records. I have try with
string comparaison et regular mapserver expression but it always the same
problem.
Thanks,
Gheysen Thibaut
Content-Type: text/html;
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dwindows-1257">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3DArial color=3D#0000ff size=3D2><SPAN =
class=3D859080213-26052004>I have=20
similar problem with Latvian characters but it is connected with=20
encoding.</SPAN></FONT></DIV>
class=3D859080213-26052004>First=20
I got not correct display of Latvian characters. That problem I solved =
by using=20
so called Rim fonts,</SPAN></FONT></DIV>
<DIV><FONT face=3DArial color=3D#0000ff size=3D2><SPAN=20
class=3D859080213-26052004>because the similar problem and solution was =
with=20
ArcView 3.x.</SPAN></FONT></DIV>
class=3D859080213-26052004></SPAN></FONT> </DIV>
class=3D859080213-26052004>But=20
when I tried to make queries, I found that apparently my current Windoze =
encoding does not fully</SPAN></FONT></DIV>
class=3D859080213-26052004>compatible with older Rim fonts=20
no problem with strings, that includes long letters, but when I used =
soft=20
letters mapserver does </SPAN></FONT></DIV>
class=3D859080213-26052004>not=20
return any results.</SPAN></FONT></DIV>
class=3D859080213-26052004>Is=20
there any solution for this problem?</SPAN></FONT></DIV>
class=3D859080213-26052004>Thanks</SPAN></FONT></DIV>
class=3D859080213-26052004>Janeks</SPAN></FONT></DIV>
<BLOCKQUOTE=20
style=3D"PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #0000ff 2px =
solid">
<DIV class=3DOutlookMessageHeader dir=3Dltr align=3Dleft><FONT =
face=3DTahoma=20
size=3D2>-----Original Message-----<BR><B>From:</B>=20
mapserver-users-admin at lists.gis.umn.edu=20
[mailto:mapserver-users-admin at lists.gis.umn.edu]<B>On Behalf Of=20
</B>gheysen.t at skynet.be<BR><B>Sent:</B> Wednesday, May 26, 2004 11:14=20
AM<BR><B>To:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B>=20
[Mapserver-users] French caracters in=20
querybyattributes<BR><BR></FONT></DIV>Hello,<BR> <BR>I have hade =
some=20
problems with french caracters. <BR>First when I read the results of a =
query=20
this caracters are not correct. I have solve this problem by modify =
the fonts=20
encoding to ISO-8859-1. Thus, now, I can make a query and read the =
results=20
correctly. <BR>But, I always have a problem with the caracter '. I =
make a=20
query to find the town "Braine l'Alleud" and I always have no records. =
I have=20
try with string comparaison et regular mapserver expression but it =
always the=20
same problem.<BR> <BR>Thanks,<BR>Gheysen=20
Thibaut<BR><BR><BR></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0000_01C4433C.7A673760--
