[Mapserver-users] NQUERY on version 3.6 vs 4.01 differences?
Daniel Morissette
dmorissette at dmsolutions.ca
Wed May 26 12:06:42 EDT 2004
Nicolas Boretos wrote:
> Hello,
> I've a mapfile in which the nquery works correctly using 3.6 based ms,
> returning results from the 3 active layers
> but not correctly on 4.01 ms e.g., only return query from a single layer.
> Has anything changed, or should I start looking at my compilations etc....
> I've found this bug reference...
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=569
> but my template is in the class.....
For sure your problem is not related to this bug since your template is
set inside the class.
I'm not sure what else would have changed in 4.0 with respect to nquery.
Perhaps Steve or someone else will have a better idea... or you could
try against version 4.2 and if the problem persists then file a bug in
bugzilla with a complete testcase to reproduce.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
