[Mapserver-users] virtual spatial data
Jenu Abraham
jenu_ab at hotmail.com
Wed May 26 11:41:42 EDT 2004
hi,
I'm using windows 2003 server with mapserver-4.1-dev-win32-php4.3.4 binaries
(This is precompiled with GDAL)
i have loaded the gdal12.dll in the winnt/system folder
and the testing2.ovf file works perfect with ogrinfo
I have tried to run it in the inline connection mode and the file connection
mode...
when i run mapserver i get this error listed below- I cant figure out whats
wrong-
the error with the inline connection string- (inside mapfile- commented out
in the source below)
msDrawMap(): Image handling error. Failed to draw layer named 'trucks'.
msOGRFileOpen(): OGR error. Open failed for OGR connection `
ODBC:sa/@localserver latlong wkbPoint WGS84 '. File not found or unsupported
format.
The error with the connection in the testing.ovf file
`C:\cgi-bin\testing2.ovf'. File not found or unsupported format.
testing2.ovf
<OGRVRTDataSource>
<OGRVRTLayer name="mylayer">
<SrcDataSource>ODBC:sa/@localserver</SrcDataSource>
<SrcLAYER>latlong</SrcLAYER>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="x" y="y"/>
</OGRVRTLayer>
</OGRVRTDataSource>
mapfile
MAP
NAME e-test-rd-jbox_
IMAGETYPE GIF
EXTENT -2236857.50 -1744057.00 2786329.50 29069.36
SIZE 800 600
SHAPEPATH "C:\cgi-bin\data\"
FONTSET "C:\cgi-bin\fonts\fonts.list"
WEB
TEMPLATE 'e-test-rd-jbox.html'
IMAGEPATH 'C:\cgi-bin\tmp\'
IMAGEURL '/tmp/'
END
PROJECTION
"init=epsg:2163"
END
LAYER # States polygon layer begins here
NAME states
DATA statesp020
STATUS DEFAULT
TYPE POLYGON
PROJECTION
"init=epsg:4326"
END
CLASS
COLOR 240 240 100
END
END # States polygon layer ends here
LAYER # start of truck position from database
NAME trucks
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "C:\cgi-bin\testing2.ovf" # file connection
#CONNECTION '<OGRVRTDataSource> # inline connection
# <OGRVRTLayer name="mylayer">
# <SrcDataSource>ODBC:sa/@localserver</SrcDataSource>
# <SrcLAYER>latlong</SrcLAYER>
# <GeometryType>wkbPoint</GeometryType>
# <LayerSRS>WGS84</LayerSRS>
# <GeometryField encoding="PointFromColumns" x="x" y="y"/>
# </OGRVRTLayer>
# </OGRVRTDataSource>'
DATA "mylayer"
STATUS DEFAULT
#LABELITEM latlong.name
PROJECTION
"init=epsg:4326"
END
CLASS
SYMBOL 1
SIZE 6
COLOR 255 0 0
#LABEL
# SIZE MEDIUM
# TYPE BITMAP
# COLOR 0 0 0
#END
END
END # end of connection layer
# End of LAYER DEFINITIONS
END # end of map file
Jenu
_________________________________________________________________
Watch LIVE baseball games on your computer with MLB.TV, included with MSN
Premium! http://join.msn.click-url.com/go/onm00200439ave/direct/01/
