[Mapserver-users] Configure: Same old error - can't find gd.h or
libgd.a/libgd.so
Tyler Mitchell
TMitchell at lignum.com
Wed May 26 14:33:03 EDT 2004
You will need gd and gd-devel packages - got those already?
In case you are not aware, you do not need to use cygwin to run mapserver
on windows. Unless you have a particular reason for doing so, I would
suggest that it is a waste of time when windows binaries are readily
available for download and almost immediate use.
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 05/26/2004 10:46:47 AM:
> Hi All,
> I've looked through the archives and the FAQ and tried the solutions
> presented, but to no avail.
> I am trying to install Mapserver 4.0.2 on Cygwin (running under Windows
> 2000).
> Please let me know if there is anything else I should be trying to do -
I'm
> running out of hair to tear out of my head.
> Here is the output from configure.sh when run:
> ... Everything running fine above here ...
> checking for strcasecmp... yes
> checking for strncasecmp... yes
> checking for strdup... yes
> configure: checking whether we should include JPEG support......
> checking for jpeg_read_header in -ljpeg... no
> libjpeg not found. JPEG support not included, possibly needed
for
> GD.
> configure: checking where FreeType 2.x is installed......
> using libfreetype from -lfreetype -lz
> checking for FT_Init_FreeType in -lfreetype... no
> using libfreetype -lfreetype -lz from system libs.
> configure: checking where Zlib is installed......
> using libz from -L/lib -lz
> configure: checking where PNG is installed......
> checking for png_init_io in -lpng... no
> PNG (libpng) library cannot be found, possibly needed for GD
> configure: checking where libXpm is installed......
> checking for XpmFreeXpmImage in -lXpm... no
> XPM (libXpm) library cannot be found, possibly needed for GD
> configure: checking where libiconv is installed......
> checking for libiconv_open in -liconv... no
> libiconv library cannot be found, possibly needed for GD
> configure: checking for GD 2.0.12 or higher......
> checking for gdImageSetAntiAliased in -lgd... no
> configure: error: "Could not find gd.h or libgd.a/libgd.so in
/usr/local/.
> Make
> sure GD 2.0.12 or higher is compiled before calling configure."
> I have tried running "./configure --with-gd=/usr/local", as well as with
> /usr/local/lib (the location of the libgd.a file) and /usr/local/include
> (the location of the gd.h file).
> I have looked through for duplicates of these files, but cannot find any
> others residing on the disk.
> --Adam
> _________________________________________________________________
> STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
> http://join.msn.com/?page=features/junkmail
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
