[Mapserver-users] querybyattributes logical expression
Tyler Mitchell
TMitchell at lignum.com
Wed May 26 14:54:35 EDT 2004
Thanks for posting the clarification Aaron. I ran into this difference
just last week and am looking forward to going back and fixing my problem
now.
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 05/26/2004 11:45:54 AM:
> I figured this out. The query string is different for different
conditions:
> For Shapefiles:
> For '>' '<' '>=' '<=' :
> ([AREA] > 4000000)
> For '=' :
> ('[NAME]' > 'prince george')
> For PostGIS:
> For numeric fields:
> (AREA > 4000000)
> For non-numeric fields:
> (NAME = 'prince george')
> Thanks for the help all,
> Aaron
> ----- Original Message -----
> From: "Ryan, Adam" <ARyan at co.linn.or.us>
> Date: Wednesday, May 26, 2004 11:24 am
> Subject: RE: [Mapserver-users] querybyattributes logical expression
> > Using "([AREA] > 4000000)" works for me. Silly question: Are you
> > sure your
> > Area field is numeric?
> > Adam
> > -----Original Message-----
> > From: AARON KONING [aaronkoning at shaw.ca]
> > Sent: Wednesday, May 26, 2004 10:54 AM
> > To: Mapserver-users at lists.gis.umn.edu
> > Cc: Eric Bridger
> > Subject: Re: [Mapserver-users] querybyattributes logical expression
> > Hi,
> > I have also used different operators in class expressions. I tried
> > yoursuggestion but it did not work. Strangely the single quotes
> > are needed
> > regardless of the data type of the field. So that the following
> > query does
> > work:
> > $queryString = "('[AREA]' = '10')"
> > $queryItem = 'AREA';
> > > > $map->querybyattributes($queryitem,$queryString,MS_MULTIPLE);
> > From: Eric Bridger <eric at gomoos.org>
> > Date: Wednesday, May 26, 2004 4:03 am
> > > At 11:11 PM 05/25/2004 -0700, AARON KONING wrote:
> > > >Hi List,
> > > >Just wondering if anyone has had success using
> > querybyattributes with
> > > >the '>', '<', '>=', '<=' operators? I have
> > > been using the 'NOT', 'AND', 'OR',
> > > >and '=' operators with success.
> > > >The following statement fails:
> > > > $queryString = "('[AREA]' > '10')"
> > > I haven't used querybyattributes() but have use comparison
> > > operators in CLASS EXPRESSION's.
> > > I would try:
> > > "([AREA] > 10)" i.e. these are number values not strings.
> > > _______________________________________________
> > > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
