[Mapserver-users] Configure: Same old error - can't find gd.h or libgd.a/lib
Adam Quiney
deathsushi at hotmail.com
Wed May 26 18:12:15 EDT 2004
I have downloaded both the gd and the gd-devel packages. I also tried
cleaning my drive of Cygwin and any installed services, restarting, then
re-installing everything. I run into the same old problem. I can locate
both gd.h and libgd.a on my drive (though in different directories, gd.h now
resides in /usr/include and libgd.a resides in /lib - this is how the cygwin
installed it did things), but mapserver's configure script still refuses to
recognize that they are there. I have made certain that there is only one
instance of both these files, so I don't believe it's a problem with
multiple versions.
What else can I do to make mapserver see the light?
--Adam
>From: Tyler Mitchell <TMitchell at lignum.com>
>To: "Adam Quiney" <deathsushi at hotmail.com>
>CC: lordadam at uvic.ca, mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] Configure: Same old error - can't find gd.h
>or libgd.a/libgd.so
>Date: Wed, 26 May 2004 11:33:03 -0700
>You will need gd and gd-devel packages - got those already?
>In case you are not aware, you do not need to use cygwin to run mapserver
>on windows. Unless you have a particular reason for doing so, I would
>suggest that it is a waste of time when windows binaries are readily
>available for download and almost immediate use.
>Tyler
>mapserver-users-admin at lists.gis.umn.edu wrote on 05/26/2004 10:46:47 AM:
> > Hi All,
> > I've looked through the archives and the FAQ and tried the solutions
> > presented, but to no avail.
> > I am trying to install Mapserver 4.0.2 on Cygwin (running under Windows
> > 2000).
> > Please let me know if there is anything else I should be trying to do -
>I'm
> > running out of hair to tear out of my head.
> > Here is the output from configure.sh when run:
> > ... Everything running fine above here ...
> > checking for strcasecmp... yes
> > checking for strncasecmp... yes
> > checking for strdup... yes
> > configure: checking whether we should include JPEG support......
> > checking for jpeg_read_header in -ljpeg... no
> > libjpeg not found. JPEG support not included, possibly needed
>for
> > GD.
> > configure: checking where FreeType 2.x is installed......
> > using libfreetype from -lfreetype -lz
> > checking for FT_Init_FreeType in -lfreetype... no
> > using libfreetype -lfreetype -lz from system libs.
> > configure: checking where Zlib is installed......
> > using libz from -L/lib -lz
> > configure: checking where PNG is installed......
> > checking for png_init_io in -lpng... no
> > PNG (libpng) library cannot be found, possibly needed for GD
> > configure: checking where libXpm is installed......
> > checking for XpmFreeXpmImage in -lXpm... no
> > XPM (libXpm) library cannot be found, possibly needed for GD
> > configure: checking where libiconv is installed......
> > checking for libiconv_open in -liconv... no
> > libiconv library cannot be found, possibly needed for GD
> > configure: checking for GD 2.0.12 or higher......
> > checking for gdImageSetAntiAliased in -lgd... no
> > configure: error: "Could not find gd.h or libgd.a/libgd.so in
>/usr/local/.
> > Make
> > sure GD 2.0.12 or higher is compiled before calling configure."
> > I have tried running "./configure --with-gd=/usr/local", as well as with
> > /usr/local/lib (the location of the libgd.a file) and /usr/local/include
> > (the location of the gd.h file).
> > I have looked through for duplicates of these files, but cannot find any
> > others residing on the disk.
> > --Adam
> > _________________________________________________________________
> > STOP MORE SPAM with the new MSN 8 and get 2 months FREE*
> > http://join.msn.com/?page=features/junkmail
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Protect your PC - get McAfee.com VirusScan Online
http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
