[Mapserver-users] How does one create .map files?
Gerry Creager N5JXS
gerry.creager at tamu.edu
Wed May 26 20:13:38 EDT 2004
I've grown really fond of starting with QGIS and letting it export a
.map file for me. It's almost never perfect, but it's a start.
Gerry
Tyler Mitchell wrote:
> Plants are welcome on this list... :)
> Many typically take an existing .map file and start pulling out stuff and
> sticking in their own stuff. Use a basic text editor like Notepad should
> be fine. I can't speak too much to your data format question, but
> MapServer can read numerous (dozens) of different raster and vector
> formats. It uses some behind-the-scenes capabilities of a library called
> GDAL/OGR for reading raster and vector data. GDAL currently supports
> DTED, but does not appear to _directly_ support the others you mentioned.
> See:
> http://remotesensing.org/pipermail/gdal-dev/2003-September/001057.html
> Any format that OGR can read in, can (more or less?) be exported into
> Shapefiles using the ogr2ogr utility. I'd highly recommend getting some
> sample data first and getting comfy :)
> Keep up the questions as your progress and we'll help you out.
> You'd really benefit from attending the MapServer Users Conference in
> Ottawa, June 9-11th. The MapServer 101 workshop would be right up your
> alley!
> mapserver-users-admin at lists.gis.umn.edu wrote on 05/26/2004 02:55:10 PM:
>>Ok, I am so green at this I practically qualify as plant life... I
>>got through a few good tutorials and didn't die.. but now I am going
>>to try to use my own (well, ok, ESRI's) shapefiles and data. But
>>how does one go about creating .map files? By hand? Is there a
>>utility? Also, I just got some NIMA files which is part of the
>>actual data that I'll be using. There are also ADRG, CADRG, CIB, &
>>DTED files that I will have to contend with. Are there utilities
>>out there for an easy conversion to shapefiles? I will be receiving
>>3.5 Terabytes worth of data. I would hate to have to create each .
>>map file by hand...
>>Thanks in advance for any help anyone can offer.
>>- sharyn
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Gerry Creager -- gerry.creager at tamu.edu
Network Engineering -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
