[Mapserver-users] selection hilite_ basic question
andre shue
andiehumpy at hotmail.com
Thu May 27 10:58:05 EDT 2004
<html><div style='background-color:'><DIV class=RTE>
<DIV>Hi Steve and List, </DIV>
<DIV>I am pretty new and unexperienced to the MS, it might be a stupid quest... anyway, I got the demo running, changed some layers, but when selecting a polygon via itemquery I am not sure. I can do an attribut search and also get results via template [area] [name] yet no map. I know I can get a map via querymap, but could not go any further on this. </DIV>
<DIV>I dont know how to build up an template with a map, including the selected polygon marked and in the centre of the map.... </DIV>
<DIV> As the where any examples I would be happy.</DIV>
<DIV>As you have any hints, please remember, I am a Geographer and low level programmer.</DIV>
<DIV>Thanks a lot.</DIV>
<DIV> </DIV>
<DIV><BR>Andreas </DIV>
<DIV> </DIV>
<DIV>PS. Another question is, is there a list of the complete template and map commands, I got the feeling there are some more commands, than I could find via the Mapserver homepage.</DIV>
<DIV> </DIV>
<DIV>Thanks anyway to the great developers of mapserver </DIV>
<DIV> </DIV>
<DIV>---------------------------------------------------------------------------------------------------------</DIV>
<DIV>Here is the template and the map.</DIV>
<DIV> </DIV>
<DIV><BR><!-- START OF MAPSERVER FORM --><BR><form name="mapserv" method="GET" action="mapserv.exe"></DIV>
<DIV> </DIV>
<DIV><table width="400" border="0" align="center"><BR> <tr> <BR> <td><BR> <p align="center"><font face="Arial Narrow">&nbsp; </font> <BR> <font face="Arial Narrow" size="6">Muldentalkreis MS <BR> Test</font></p><BR> <p>&nbsp;</p><BR> <table width="466" border="1"><BR> <tr> <BR> <td width="211"></DIV>
<DIV> </DIV>
<DIV><!-- SPECIFY MAP MODE --><BR> Attribut eingeben<b> (Achtung!!! Mapmode = Attributabfrage)</b><div align="center"><BR><input type="TEXT" size= "30" name= "qstring" value=""><input type="submit" value="ENTER"></div><BR> <div align="center">&nbsp;</div><BR> <div align="center">&nbsp;</div><BR> <div align="center">Map Mode:<br><BR> <select name="mode"><BR> <option value="browse" [browse_select]>Browse</option><BR> <option value="query" [query_select]>Abfrage</option><BR> <option value="itemquery" [itemquery_select]>Attributabfrage</option> <BR> <BR> </select><BR> </div><BR> </td><BR> <td width="77"><BR><!-- FORM SUBMIT BUTTON --><BR> <div align="center"><BR> <input type="submit" name="submit" value="Refresh"><BR> </div><BR> </td><BR> <td width="156"></DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV><BR><!-- ZOOM/PAN CONTROLS --><BR> <div align="center">Map Control: <br><BR> <select name="zoom"><BR> <option value="4" [zoom_4_select]>Zoom In 4x</option><BR> <option value="3" [zoom_3_select]>Zoom In 3x</option><BR> <option value="2" [zoom_2_select]>Zoom In 2x</option><BR> <option value="1" [zoom_1_select]>Recenter</option><BR> <option value="-2" [zoom_-2_select]>Zoom Out 2x</option><BR> <option value="-3" [zoom_-3_select]>Zoom Out 3x</option><BR> <option value="-4" [zoom_-4_select]>Zoom Out 4x</option><BR> </select><BR> </div><BR> </td><BR> </tr><BR> <tr><BR> <BR> <BR><!-- DISPLAY THE MAPSERVER-CREATED MAP IMAGE --><BR> <td colspan="3" align="center" valign="top" width="390"><BR> <input type="image" name="img" src="[img]" width="[mapwid
th]" height="[mapheight]"><BR> </td><BR> </tr><BR> </table><BR> </td><BR> </tr><BR></table></DIV>
<DIV> </DIV>
<DIV><!-- Attributabfrage --><BR>&nbsp;</DIV>
<DIV> </DIV>
<DIV><BR><!-- HIDDEN MAPSERVER CGI VARIABLES --><BR><input type="hidden" name="imgxy" value="[center]"><BR><input type="hidden" name="imgext" value="[mapext]"><BR><input type="hidden" name="map" value="[map]"><BR><input type="hidden" name="root" value="[root]"><BR><input type="hidden" name="savequery" value="true"><BR><input type="hidden" name="qlayer" value="mtl"><BR><input type="hidden" name="qitem" value="GEMEINDE"</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV></form><BR></body><BR></html></DIV>
<DIV> </DIV>
<DIV> ----------------------------------------------------------------------------------------------------------------</DIV>
<DIV>MAP<BR> IMAGETYPE PNG<BR> EXTENT 4528581.187561 5713247.167603 4573608.666901 5651344.554810<BR> SIZE 750 750<BR> SHAPEPATH "data"<BR> IMAGECOLOR 255 255 255</DIV>
<DIV> </DIV>
<DIV><BR>QUERYMAP<BR> SIZE 600 600<BR> STATUS OFF <BR> STYLE HILITE<BR> COLOR 23 35 24<BR>END</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>WEB<BR> TEMPLATE 'test.html'<BR> IMAGEPATH 'tmp/'<BR> IMAGEURL 'tmp/'<BR>END</DIV>
<DIV> </DIV>
<DIV><BR> LAYER<BR> NAME mtl<BR> TYPE POLYGON<BR> DATA mtl<BR> PROJECTION<BR> proj=tmerc <BR> lat_0=0.000000000 <BR> lon_0=12.000000000 <BR> k=1.000000 <BR> x_0=4500000.000 <BR> y_0=0.000 <BR> ellps=bessel <BR> units=m <BR> no_defs <BR>END #line114<BR> STATUS DEFAULT<BR> CLASSITEM 'GEMEINDE'<BR> LABELITEM 'GEMEINDE'<BR> #LABELMINSCALE 80000 <BR> CLASS<BR> NAME "GEMEINDE"<BR> EXPRESSION /./<BR> OUTLINECOLOR 0 0 0<BR> COLOR 255 255 217 <BR> LABEL<BR>END<BR> TEMPLATE "mtl.html"<BR> END<BR> HEADER "mtl_header.html"<BR> FOOTER "mtl_footer.html"</DIV>
<DIV> </DIV>
<DIV><BR>END<BR></DIV>
<DIV>---------------------------------------------------------------------------------------------------</DIV>
<P><BR><BR></P></DIV></div><br clear=all><hr>MSN 8 helps <a href="http://g.msn.com/8HMBEN/2752??PS=47575">ELIMINATE E-MAIL VIRUSES.</a> Get 2 months FREE*.</html>
