[Mapserver-users] nested tiles
Steve Lime
steve.lime at dnr.state.mn.us
Fri May 28 15:11:15 EDT 2004
I think in theory, at least with raster data, ANY layer should usable as
a index as long it contains
polygon features. I know you can use PostGIS or SDE layers as index
layers so...
Give it a try, easy enough to test if you can get the data setup
right.
Steve
>>> Stephen Woodbridge <woodbri at swoodbridge.com> 5/28/2004 10:29:34 AM
Jan Hartmann wrote:
> Ed McNierney wrote:
>> Jan -
>> Yes, I agree with Steve - I doubt you need this. I would recommend
you
>> create a single tileindex and then be sure to create quadtree index
on
>> the tileindex by using shptree.
YES, Yes, yes! you should create shptree (*.qix) files for ALL
shapefiles. Everybody should remember this for all shapefiles as it
provides a significant performance boost in in 99.99% of the cases.
find /path/to/data -follow -name "*.shp" -exec shptree {} \;
> OK, I'll do that; it's a small country after all. The quadtree is a
good
> suggestion, perhaps that's what I did read about. Just for the
record:
> *are* nested tiles possible?
Not that I know of. I don't know if the new changes that Steve Lime
made
to separate off the tileindex into it's own layer might provide
functionality for such a feature or not.
-Steve W.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
