[Mapserver-users] How does one create .map files?
Merrett, Mike
mike.merrett at city.whitehorse.yk.ca
Thu May 27 13:59:49 EDT 2004
here is part of some code I am developing for user selection and then
building of map files: (not all the code is here - and each database entry
Details column contains a complete Layers section (which I copy/paste into
the DB after verifying it works) then I call the processing script (mostly
gmap75) with the name of the map file.
Hope this helps,
Mike Merrett
function do_build_map_file() {
// get a random non existing file name for the map file
do {
$tmpfname = "tmp/TMPMAP". trim(strval( mt_rand( 1, (2^14) *
mt_rand(1,(2^15)) ))) .".map";
} while ( ! file_exists( $tmpfname));
$handle = fopen($tmpfname, "w");
map_put_headers( $handle ); // put the headers (i.e. everything
above the layers in a normal map file
//layers are selected -- now build the map file
$link = dbx_connect (DBX_MYSQL, "localhost", "mysql",
"MapServer_Layers", "MapServer_Layers")
or die ("could not connect");
foreach( $_POST['layers'] as $a_Layer ) {
$sql = "select Details"
." from MapServer_Layers "
." where LayerName = '" . $a_Layer ."'"
$result = dbx_query($link, $sql, DBX_RESULT_INDEX |
DBX_RESULT_INFO );
fwrite( $handle, $result->data[0][0]);
fwrite( $handle, "\n\n");
fwrite($handle, "\n\nEND");
fclose($handle);
return ($tmpfname);
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Alejandro
Vartabedian
Sent: May 27, 2004 10:33 AM
To: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] How does one create .map files?
well,
based on Ed theory, i think some php Smarty templates and
phpmapscript
can do the job well and easy.
i'll try this and post some news.
good luck.
Namnath, Sharyn wrote:
> Thanks to everyone who offered (and is still offering) suggestions. I
will
> certainly look into all of them. I know I'm not completely enamored with
> the idea of creating a map file for every map I'm going to need, but if I
> have to then so be it. I too am interested in your method Ed. If you
care
> to share, I bet a lot more of us are interested.
> - Sharyn
> From: Tyler Mitchell [mailto:TMitchell at lignum.com]
> Sent: Thursday, May 27, 2004 8:03 AM
> To: Ed McNierney
> Cc: mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] How does one create .map files?
> Sounds interesting Ed, I'd love to see an example of your methodology.
> Tyler
> mapserver-users-admin at lists.gis.umn.edu wrote on 05/26/2004 06:57:35 PM:
>>Sharyn -
>>For several years now I've been using the C preprocessor to take
>>"template" MAP files and do #includes, macro expansion, etc. It's
>>pretty convenient if you need to either generate lots of MAP files or
>>lots of layers in a MAP file. We've got around 150+ MAP files, around
>>60 or 70 layers, and nearly 350,000 source data files, and it is a good
>>way to keep things organized.
>> - Ed
>>Ed McNierney
>>President and Chief Mapmaker
>>TopoZone.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
