[Mapserver-users] How do I create a georeferenced tiff file...
Zamil Murji
Zamil.Murji at divestco.com
Thu May 27 16:36:40 EDT 2004
Thanks Ethan,
I'm very new to GDAL, so forgive me if i'm wrong, but isn't gdal_translate used to translate between GDAL formats? How is postgis a GDAL format? It doesn't appear in the list of formats that are supported by GDAL that you posted below...
Thanks in advance,
Zamil
-----Original Message-----
From: Ethan Alpert [mailto:ealpert at digitalglobe.com]
Sent: Thursday, May 27, 2004 2:32 PM
To: Zamil Murji; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] How do I create a georeferenced tiff
file...
I think the tool you should use is gdal_translate.
Usage: gdal_translate [--version]
[-ot {Byte/Int16/UInt16/UInt32/Int32/Float32/Float64/
CInt16/CInt32/CFloat32/CFloat64}] [-not_strict]
[-of format] [-b band] [-outsize xsize[%] ysize[%]]
[-scale [src_min src_max [dst_min dst_max]]]
[-srcwin xoff yoff xsize ysize] [-a_srs srs_def]
[-projwin ulx uly lrx lry] [-co "NAME=VALUE"]*
[-mo "META-TAG=VALUE"]* [-quiet]
src_dataset dst_dataset
GDAL 1.1.9.0, released 2003/06/27
The following format drivers are configured and support output:
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
ELAS: ELAS
AAIGrid: Arc/Info ASCII Grid
DTED: DTED Elevation Raster
PNG: Portable Network Graphics
JPEG: JPEG JFIF
MEM: In Memory Raster
GIF: Graphics Interchange Format (.gif)
BSB: Maptech BSB Nautical Charts
XPM: X11 PixMap Format
BMP: MS Windows Device Independent Bitmap
PNM: Portable Pixmap Format (netpbm)
ENVI: ENVI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Atlantis MFF Raster
MFF2: Atlantis MFF2 (HKV) Raster
FIT: FIT Image
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Zamil
Murji
Sent: Thursday, May 27, 2004 1:35 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] How do I create a georeferenced tiff file...
Hello list,
I've got a postgis table with approximately 500000 rows. I would like to
extract that data at various scales into georeferenced tiff images. How
do I do this? What programs can I use?
Thanks for your help,
Zamil
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
