[Mapserver-users] querymap object in php/mapscript
bartvde at xs4all.nl
Fri May 28 06:22:45 EDT 2004
according to the following bug there is not yet a QueryMapObj in
PHP/Mapscript:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=535
Best regards,
Bart
> Daniel Morissette wrote:
>> Joukje de Haan wrote:
>>> Hello,
>>> I'd like to change the size of the querymap object using php. I can't
>>> find any info on the querymap object in the class reference. So I
>>> tried something like this:
>>> $qmap = $map->querymap;
>>> $qmap->width = 200;
>>> $qmap->height = 150;
>>> It doesn't give me any errors, but it doesn't have any effect either
>>> $map->drawQuery still returns an image of the size as it is written in
>>> the mapfile. Am I missing something?
>> You have to use the set() method to set any class member variables in
>> PHP MapScript:
>> $qmap->set("width", 200);
>> $qmap->set("height", 150);
>> Daniel
> Sorry, forgot to tell that I tried that too. It gives the following error:
> Fatal error: Call to a member function on a non-object
> The non-object seems to be $qmap
> If $qmap isn't an object, I would think that $map->querymap gives an error
> (something like "querymap is not a member of the $map object).
> Any further ideas?
> Joukje
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
