[Mapserver-users] Can't locate object method "TIEHASH"
Sean Gillies
sgillies at frii.com
Fri May 28 13:03:39 EDT 2004
On May 28, 2004, at 10:30 AM, Lowell Filak wrote:
> The following message was sent by Sean Gillies <sgillies at frii.com> on
> Fri, 28 May 2004 08:00:31 -0600.
>> Will one of you enter this as a new MapScript-SWIG bug? If it turns
>> out that
>> none of us are using the msDBF* functions through mapscript, then I
>> should see
>> about removing them from the module.
> Can it be removed? I was under the impression that TCL/MapScript
> needed it.
> Lowell
The mapscriptsupp.tcl file hasn't been modified since MapServer 3.5.
I'll bet
a beer at MUM2 that it is already broken in spots against MapServer 4.3
(CVS).
I'd really like to know if there are any users of it. I won't make any
radical
changes without finding out. But, as a general principle, I advocate
removing
unused stuff from the module as soon as we can safely do so.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
