[Mapserver-users] XML Mapfile
Sean Gillies sgillies at frii.com
Fri May 28 10:22:18 PDT 2004
I agree with Paul.  SLD could be a good match for your app.  In the 4.2
release
the layerObj has generateSLD and applySLD methods.  Think of it as a
stylesheet
for your layer.
BTW -- Paul, it would make it so much easier to make sense of these
threads if
you would follow suit on bottom-posting vs top-posting.  I don't think
one is
necessarily better than the other, but since you replied to a thread in
which I had
already started bottom-posting, you should follow suit.  For the
benefit of future
readers in the archive.  Just my $.02.
cheers,
Sean
On May 28, 2004, at 10:59 AM, Paul Spencer wrote:
> this would be WMS and SLD.  The limitation would be that MapServer SLD
> support does not fully describe all the styling options available to a
> normal MapServer layer.
> I think I see where you are going with this, I just don't think it is
> a good idea to invent yet another way of doing this if you already
> have a mechanism in place that could do it with only minor
> modifications.
> The concept is good, but it doesn't need to be something new since
> this problem has already been solved.  Unless there is some technical
> reason why WMS/SLD wouldn't serve this purpose?
> Paul
More information about the MapServer-users mailing list
