[Mapserver-users] Png Error
IT Devel
devel at itdownunder.com.au
Fri May 28 14:07:28 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0004_01C44532.76B1C660
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hello
I am new to MapServ
I have MapServ installed on my Red Hat 7.3 server
I have installed Workshop and get the following error.
libpng warning: Application was compiled with png.h from libpng-1.2.5
libpng warning: Application is running with png.c from libpng-1.0.14
gd-png: fatal libpng error: Incompatible libpng version in application
and library
[Sat May 29 04:17:46 2004] [error] [client 203.217.45.80] Premature end
of script headers: /var/www/cgi-bin/mapserv
A locate on png.c returne:
[root at tanami mapserver-4.2.0]# locate png.c
/usr/src/gd-2.0.22/gd_png.c
/usr/src/gd-2.0.22/gd2topng.c
/usr/src/gd-2.0.22/gdparttopng.c
/usr/src/gd-2.0.22/gdtopng.c
/usr/src/gd-2.0.22/webpng.c
/usr/src/libpng-1.2.5/contrib/gregbook/readpng.c
/usr/src/libpng-1.2.5/contrib/gregbook/wpng.c
/usr/src/libpng-1.2.5/contrib/gregbook/writepng.c
/usr/src/libpng-1.2.5/contrib/pngminus/pnm2png.c
/usr/src/libpng-1.2.5/png.c
/usr/src/libpng-1.2.5/projects/borland/libpng.cpp
A locate on png.h returns:
/usr/include/mozilla-1.0.2/png/png.h
/usr/include/png.h.old
/usr/local/include/libpng/png.h
/usr/local/include/png.h
/usr/local/interchange/foundation/pages/survey/graph.png.html
/usr/local/interchange/mike/pages/survey/graph.png.html
/usr/src/interchange-5.0.0/dist/foundation/pages/survey/graph.png.html
/usr/src/interchange-4.9.9/dist/foundation/pages/survey/graph.png.html
/usr/src/interchange-5.0.1/dist/foundation/pages/survey/graph.png.html
/usr/src/libpng-1.2.5/contrib/gregbook/readpng.h
/usr/src/libpng-1.2.5/contrib/gregbook/writepng.h
/usr/src/libpng-1.2.5/png.h
Any guidance would be greatly appreciated.
Andrew Rich
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C44532.74F52240">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"time"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hello<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I am new to <span class=3DSpellE>MapServ</span> =
font-family:Arial'>I have <span class=3DSpellE>MapServ</span> installed =
on my Red
Hat 7.3 server<o:p></o:p></span></font></p>
font-family:Arial'>I have installed Workshop and get the following =
error.<o:p></o:p></span></font></p>
<p class=3DMsoNormal><span class=3DSpellE><span class=3DGramE><font =
size=3D2
style=3D'font-size:10.0pt;font-family:Arial'>libpng</span></font></span><=
/span><font
style=3D'font-size:10.0pt;font-family:Arial'> warning:
Application was compiled with <span class=3DSpellE>png.h</span> from =
libpng-1.2.5<o:p></o:p></span></font></p>
size=3D2
/span><font
Application<span style=3D'mso-spacerun:yes'> </span>is<span
style=3D'mso-spacerun:yes'> </span>running with <span =
class=3DSpellE>png.c</span>
from libpng-1.0.14<o:p></o:p></span></font></p>
size=3D2
style=3D'font-size:10.0pt;font-family:Arial'>gd-png</span></font></span><=
/span><font
style=3D'font-size:10.0pt;font-family:Arial'>:<span
style=3D'mso-spacerun:yes'> </span>fatal <span =
class=3DSpellE>libpng</span>
error: Incompatible <span class=3DSpellE>libpng</span> version in =
application and
library<o:p></o:p></span></font></p>
font-family:Arial'>[Sat May 29 </span></font><st1:time Hour=3D"16" =
Minute=3D"17"><font
style=3D'font-size:10.0pt;font-family:Arial'>04:17:46</span></font></st1:=
time><font
style=3D'font-size:10.0pt;font-family:Arial'> 2004] [<span
class=3DGramE>error</span>] [<span class=3DGramE>client</span> =
203.217.45.80]
Premature end of script headers: /<span =
class=3DSpellE>var/www/cgi-bin/mapserv</span><o:p></o:p></span></font></p=
font-family:Arial'>A <span class=3DGramE>locate</span> on <span =
<span class=3DSpellE>returne</span>:<o:p></o:p></span></font></p>
font-family:Arial'>[<span class=3DSpellE>root at tanami</span> =
mapserver-4.2.0]#
locate <span class=3DSpellE>png.c</span><o:p></o:p></span></font></p>
font-family:Arial'>/usr/src/gd-2.0.22/gd_png.c<o:p></o:p></span></font></=
p>
font-family:Arial'>/usr/src/gd-2.0.22/gd2topng.c<o:p></o:p></span></font>=
</p>
font-family:Arial'>/usr/src/gd-2.0.22/gdparttopng.c<o:p></o:p></span></fo=
nt></p>
font-family:Arial'>/usr/src/gd-2.0.22/gdtopng.c<o:p></o:p></span></font><=
/p>
font-family:Arial'>/usr/src/gd-2.0.22/webpng.c<o:p></o:p></span></font></=
p>
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/readpng.c<o:p><=
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/wpng.c<o:p></o:=
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/writepng.c<o:p>=
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/pngminus/pnm2png.c<o:p><=
font-family:Arial'>/usr/src/libpng-1.2.5/png.c<o:p></o:p></span></font></=
p>
font-family:Arial'>/usr/src/libpng-1.2.5/projects/borland/libpng.cpp<o:p>=
returns:<o:p></o:p></span></font></p>
font-family:Arial'>/usr/include/mozilla-1.0.2/png/png.h<o:p></o:p></span>=
</font></p>
font-family:Arial'>/<span =
class=3DSpellE>usr/include/png.h.old</span><o:p></o:p></span></font></p>
class=3DSpellE>usr/local/include/libpng/png.h</span><o:p></o:p></span></f=
ont></p>
class=3DSpellE>usr/local/include/png.h</span><o:p></o:p></span></font></p=
font-family:Arial'>/usr/local/interchange/foundation/pages/survey/graph.p=
ng.html<o:p></o:p></span></font></p>
font-family:Arial'>/usr/local/interchange/mike/pages/survey/graph.png.htm=
font-family:Arial'>/usr/src/interchange-5.0.0/dist/foundation/pages/surve=
y/graph.png.html<o:p></o:p></span></font></p>
font-family:Arial'>/usr/src/interchange-4.9.9/dist/foundation/pages/surve=
font-family:Arial'>/usr/src/interchange-5.0.1/dist/foundation/pages/surve=
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/readpng.h<o:p><=
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/writepng.h<o:p>=
font-family:Arial'>/usr/src/libpng-1.2.5/png.h<o:p></o:p></span></font></=
p>
font-family:Arial'>Any guidance would be greatly =
appreciated.<o:p></o:p></span></font></p>
font-family:Arial'>Andrew Rich<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0004_01C44532.76B1C660--
