[Mapserver-users] XML Mapfile
Stephen Woodbridge
woodbri at swoodbridge.com
Fri May 28 14:04:33 EDT 2004
OK so SLD the same as Web Map Contexts?
It also sounds like a bunch of this stuff is under active development.
How much is ready for prime-time on 4.01 and 4.2?
Is there documentation for it, sounds like I have a bunch of reading to do.
The only technical reason for going a different route is the fact that a
lot of our infrastructure is based on mapscript, perl, php, etc.
Converting it to work with WMS and SLD "might" be a lot bigger task than
writing a mapfile -> XML -> mapfile converter.
-Steve W.
Paul Spencer wrote:
> this would be WMS and SLD. The limitation would be that MapServer SLD
> support does not fully describe all the styling options available to a
> normal MapServer layer.
> I think I see where you are going with this, I just don't think it is a
> good idea to invent yet another way of doing this if you already have a
> mechanism in place that could do it with only minor modifications.
> The concept is good, but it doesn't need to be something new since this
> problem has already been solved. Unless there is some technical reason
> why WMS/SLD wouldn't serve this purpose?
> Paul
> Stephen Woodbridge wrote:
>> Paul Spencer wrote:
>>> Um. This sounds a lot like Web Map Contexts ;) Except that only
>>> works with WMS data ... but how were you thinking that the client
>>> would request the map remotely?
>> OK, this is not total thought through yet and there may be better ways
>> of doing this. But the idea would be that you could make an xml
>> service available that a user could request a mapfile and get it in
>> xml, they could then modify colors, layers, min/max scales, and
>> labeling (basically the symbology) but not the structure other than
>> turning layers on/off.
>> A variant of this idea would be to create and abstraction of the
>> symbology and return that as an xml document and when it is returned
>> then regenerate a new mapfile based on the abstraction. When I create
>> mapfiles I generate an excel spread sheet with with symbolic layers
>> like "ROADS" and then describe the styling and data at the various
>> zoom scales and do that for each virtual layer, then that gets
>> expanded into a Mapserver mapfile and physical layers.
>> I kind of like the later option because it is more abstract and hides
>> all the syntactic details of a mapserver mapfile which nobody really
>> needs to know about.
>> -Steve
>>>> Sean Gillies wrote:
>>>>> On May 28, 2004, at 5:16 AM, Stephen Woodbridge wrote:
>>>>>> Hi all,
>>>>>> There is a pretty extensive discussion on XML mapfiles in the
>>>>>> archives, did anything come of this? Did anyone build any
>>>>>> conversion tools?
>>>>>> Thanks,
>>>>>> -Steve W.
>>>>> My XML project is not yet bearing any fruit. Are you going to the
>>>>> users meeting?
>>>>> Maybe we could see if any like-minded folks want to discuss it there.
>>>> MUM2 is still a question at this point for me.
>>>> I am interested in doing something with Perl.
>>>> One idea is to:
>>>> write a perl script to convert maplexer.l into a Parse::Lex script
>>>> and mapparser.y to a Parse::Yapp script. This would allow us to
>>>> generate perl code that could accurately read mapfiles based on the
>>>> mapserver grammar files. - this may be more trouble than it is worth
>>>> as I don't know much about these tools.
>>>> My goal would be to be able to read a mapfile and send it as xml to
>>>> another client. They could make changes to it and request a map
>>>> based on the modified mapfile. The modified mapfile would be
>>>> validated and converted back to a Mapfile or would be dynamically
>>>> instanciated in Mapscript. I don't think Mapscript supports all the
>>>> functionality we need to do the later.
>>>> -Steve
>>>> _______________________________________________
>>>> Mapserver-users mailing list
>>>> Mapserver-users at lists.gis.umn.edu
>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
