[Mapserver-users] Compiling problems ms 4.2+PHP5
Daniel Morissette
dmorissette at dmsolutions.ca
Sat May 29 07:51:53 EDT 2004
Merlos wrote:
> Hello,
> I'm trying to compile mapserver 4.2 and php5-RC2, has anybody succeed to
> compile it with php5 or do I have to use PHP 4.3.x? I am doing something
> wrong? Any advice?
I wouldn't expect things to work with PHP5. You will have to use PHP 4.3.x
> I found another problem. If I try to compile with --with-postgis and
> --with-mygis I got another error message. It seems that there are repeated
> functions, is it possible to compile allowing both data sources?
There is already a bug about this:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=632
In the last comment I propose that the duplicate functions should be
made static in both mappostgis.c and mapmygis.c but I was not setup to
test that. Can you please try changing the following:
char *DATAERRORMESSAGE(char *dString, char *preamble)
to
static char *DATAERRORMESSAGE(char *dString, char *preamble)
and the same for all other duplicate functions, in both source files,
and report to the bug if that fixes the issue. I'm 99% sure it will but
don't want to commit that to CVS until someone tests it.
> Finally, When I try to compile with ming (I've installed latest release ming
> 0.3beta1), when running configure I got this message:
> checking if MING/Flash support requested... yes, user supplied MING directory
> ./configure: line 8175: -lming: command not found
command not found? That's odd.
> And then when running make:
> gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
> -DUSE_PROJ_API_H -DUSE_WMS_SVR -DUSE_WMS_LYR -DUSE_WFS_SVR -DUSE_MING_FLASH
> -DUSE_TIFF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DUSE_PDF
> -DUSE_OGR -DUSE_GDAL -DUSE_POSTGIS -DUSE_MYGIS -I/usr/local/include
> -I/usr/local/include -I/usr/local/pgsql/include -I/usr/include/mysql
> -I/usr/local/include -I/usr/local mapswf.c -o mapswf.o
> mapswf.c: In function `BuildButtonFromGD':
> mapswf.c:444: warning: passing arg 2 of `SWFButton_addShape' from
> incompatible pointer type
Maybe something radical changed in v0.3 making it incompatible with
v0.2. Perhaps file a bug in bugzilla about this one.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
