[Mapserver-users] classitem: more than 1 attribute?
Bart van den Eijnden
bartvde at xs4all.nl
Sun May 30 13:17:11 EDT 2004
you can do this by using the columns needed in the EXPRESSION itself, e.g.:
EXPRESSION (('[Cat]' eq 'A') AND ([Zosmar] > 0))
where Cat is a string column, and Zosmar is a number column.
Best regards,
Bart
On Sun, 30 May 2004 18:38:25 +0200, Roman Meier <mapserver at gismap.ch>
wrote:
> Hi list
> Is classitem limited to one attribute?
> I would like to build classes depending on 2 attributes, like CLASSITEM
> "type1" + "type2".
> Is this possible? Any hints?
> Thanks in advance
> Roman
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
