[Mapserver-users] Simple Application
Andrew Rich
devel at itdownunder.com.au
Mon May 31 11:43:25 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_000B_01C44779.D5142A60
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi All
I think to many this would be a simple task but I would like some
suggestions about the best path to follow for the following.
All on RH Linux
I have a list of objects in a mysql database. I can add the starting
and ending Long/Lat into that database for each object.
I want to show a Map (mapserver) and as you Pan or move I want to be
able activate a Query with returns the current location. Then lookup
the matching objects in the mysql table. I think this will be done by
calls in the other application.
The mysql table is part of another application and with thousands of
records I don't with to duplicate them is possible.
So is the Itasca a good place to start from?
I would start with a world map and drill down to country, most likely
Australia. Then click button to find objects which contain this point.
The detail of the maps is for assisting in the search not to look at all
the layers (at this point).
So what type of maps and images would you recommend?
Thank you
Andrew Rich
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C44779.D4308120">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"country-region"/>
<o:SmartTagType =
name=3D"place"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi All<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I think <span class=3DGramE>to</span> many this would =
be a
simple task but I would like some suggestions about the best path to =
follow for
the following.<o:p></o:p></span></font></p>
font-family:Arial'>All on RH Linux<o:p></o:p></span></font></p>
font-family:Arial'>I have a list of objects in a <span =
class=3DSpellE>mysql</span>
database.<span style=3D'mso-spacerun:yes'> </span>I can add the =
starting
and ending Long/Lat into that database for each =
object.<o:p></o:p></span></font></p>
font-family:Arial'>I want to show a Map (<span =
class=3DSpellE>mapserver</span>) and
as you Pan or move I want to be able activate a Query with returns the =
current
location.<span style=3D'mso-spacerun:yes'> </span>Then lookup the =
matching objects
in the <span class=3DSpellE>mysql</span> table.<span
style=3D'mso-spacerun:yes'> </span>I think this will be done by =
calls in
the other application.<o:p></o:p></span></font></p>
font-family:Arial'>The <span class=3DSpellE>mysql</span> table is part =
of another
application and with thousands of records I don’t with to =
duplicate them
is possible.<o:p></o:p></span></font></p>
font-family:Arial'>So is the </span></font><st1:place><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Itasca</span></font></st1:pl=
ace><font
style=3D'font-size:10.0pt;font-family:Arial'> a good
place to start from?<o:p></o:p></span></font></p>
font-family:Arial'>I would start with a world map and drill down to =
country, most
likely </span></font><st1:country-region><st1:place><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Australia</span></font></st1=
:place></st1:country-region><font
style=3D'font-size:10.0pt;font-family:Arial'>. Then click
button to find objects which contain this =
point.<o:p></o:p></span></font></p>
font-family:Arial'>The detail of the maps is for assisting in the search =
not to
look at all the layers (at this point).<o:p></o:p></span></font></p>
font-family:Arial'>So what type of maps and images would you =
recommend?<o:p></o:p></span></font></p>
font-family:Arial'>Thank you<o:p></o:p></span></font></p>
font-family:Arial'>Andrew Rich<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_000B_01C44779.D5142A60--
