[Mapserver-users] mscalculate() and explode()
julius muchemi
muchemijg at yahoo.com
Mon May 31 04:37:35 EDT 2004
--0-2129600517-1085992655=:28075
Content-Type: text/plain; charset=us-ascii
Yes the array explode has worked as per your instructions
Could also somebody sought me out on this next error on the same coding
Fatal error: [MapServer Error]: msCalculateScale(): Invalid image
extent. in C:\Program Files\Apache Group\Apache2\htdocs\Nakmap\nakint.php on line 19
AARON KONING <aaronkoning at shaw.ca> wrote:
The PHP function 'explode' requires two arguments and you have only provided one. Change the explode function on line 18 to include the two arguments as per below.
Function definition from php.net:
array explode ( string separator, string string [, int limit])
Aaron
----- Original Message -----
Date: Saturday, May 29, 2004 5:57 am
Subject: [Mapserver-users] mscalculate() and explode()
> i have ahead with the project and after displaying the the layer
> now want to add zoom and pan capabilities to the previous code.
> I'm still on windows 2000.
> i have the following error in browser which i dont know how to
> solve
> Warning: Wrong parameter count for explode() in C:\Program
> Files\Apache Group\Apache2\htdocs\Nakmap\nakint.php on line 18
> The code looks like this:
> ?php
> dl("php_mapscript_4.0.1.dll");
> $map_path = "C:/Program Files/Apache Group/Apache2/htdocs/Nakmap/";
> $map = ms_newMapObj($map_path."nakuru.map");
> $val_zsize=3;
> $check_pan="CHECKED";
> " MEHOD="POST">
> $extent_to_set=explode("EXTENT");
> $map-
> >setextent($extent_to_set[0],$extent_to_set[1],$extent_to_set[2],$extent_to_set[3]);$my_extent=ms_newpointObj();
> $my_point->setXY("mapa_x", "mapa_y");
> $my_extent = ms_newrectObj();
> $my_extent = $map->setextent($extent_to_set[0], $extent_to_set[1],
> $extent_to_set[2], $extent_to_set[3]);
> > $zoom_factor=("zoom")*("zsize");
> if ($zoom_factor==0)
> $zoom_factor=1;
> $CHECK_zout="";
> $check_zin="";
> else if ($zoom_factor<0)
> $check_pan="";
> $check_zout="CHECKED";
> $check_zin="";
> else
> $check_pan="";
> $check_zout="";
> $check_zin="CHECKED";
> $Val_zsize=abs($zoom_factor);
> $map->zoompoint ($zoom_factor, $my_point, $map->width, $map-
> >height, $my_extent);
> $image = $map->draw();
> $image_url=$image->saveWebImage();
> $extent_to_html = $map->EXTENT->minx." ".$map->EXTENT->miny."
> ".$map->EXTENT->maxx." ".$map->EXTENT->maxy;
> Could trace anything wrong with my zoom and pan code. SPecifically
> this code
> $map-
> >setextent($extent_to_set[0],$extent_to_set[1],$extent_to_set[2],$extent_to_set[3]);and
> as seem to be source of all the above errors
> Muchemi
> Do you Yahoo!?
> Friends. Fun. Try the all-new Yahoo! Messenger
Do you Yahoo!?
Content-Type: text/html; charset=us-ascii
<DIV>Yes the array explode has worked as per your instructions</DIV>
<DIV> </DIV>
<DIV>Could also somebody sought me out on this next error on the same coding</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV>Fatal error: [MapServer Error]: msCalculateScale(): Invalid image <BR> extent. in C:\Program Files\Apache Group\Apache2\htdocs\Nakmap\nakint.php on line 19<BR><BR><BR><B><I>AARON KONING <aaronkoning at shaw.ca></I></B> wrote:</DIV>
<BLOCKQUOTE class=replbq style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid">The PHP function 'explode' requires two arguments and you have only provided one. Change the explode function on line 18 to include the two arguments as per below.<BR><BR>Function definition from php.net:<BR><BR>array explode ( string separator, string string [, int limit])<BR><BR>Aaron<BR><BR><BR><BR>----- Original Message -----<BR>From: julius muchemi <MUCHEMIJG at YAHOO.COM><BR>Date: Saturday, May 29, 2004 5:57 am<BR>Subject: [Mapserver-users] mscalculate() and explode()<BR><BR>> i have ahead with the project and after displaying the the layer <BR>> now want to add zoom and pan capabilities to the previous code. <BR>> I'm still on windows 2000. <BR>> i have the following error in browser which i dont know how to <BR>> solve <BR>> <BR>> Warning: Wrong parameter count for explode() in C:\Program <BR>> Files\Apache Group\Apache2\htdocs\Nakmap\nakint.php on line
18<BR>> Fatal error: [MapServer Error]: msCalculateScale(): Invalid image <BR>> extent. in C:\Program Files\Apache <BR>> Group\Apache2\htdocs\Nakmap\nakint.php on line 19<BR>> The code looks like this:<BR>> ?php <BR>> dl("php_mapscript_4.0.1.dll");<BR>> $map_path = "C:/Program Files/Apache Group/Apache2/htdocs/Nakmap/";<BR>> $map = ms_newMapObj($map_path."nakuru.map");<BR>> $val_zsize=3;<BR>> $check_pan="CHECKED";<BR>> ?><BR>> <BR>> <BR>> <BR>> <BR>> <BR>>
<TABLE cellSpacing=0 bgColor=green border=2 cellpanding="1">
<TBODY>
<TR>
<TD><BR>>
<FORM action="<?=$php_self;?>" MEHOD="POST"><BR>> </TD>
<TD><BR>> <?<br>> {<BR>> $extent_to_set=explode("EXTENT"); <BR>> $map-<BR>> >setextent($extent_to_set[0],$extent_to_set[1],$extent_to_set[2],$extent_to_set[3]);$my_extent=ms_newpointObj();<BR>> $my_point->setXY("mapa_x", "mapa_y");<BR>> $my_extent = ms_newrectObj();<BR>> $my_extent = $map->setextent($extent_to_set[0], $extent_to_set[1], <BR>> $extent_to_set[2], $extent_to_set[3]);<BR>> }<BR>> ?><BR>> <?<br>> $zoom_factor=("zoom")*("zsize");<BR>> if ($zoom_factor==0)<BR>> {<BR>> $zoom_factor=1;<BR>> $check_pan="CHECKED";<BR>> $CHECK_zout="";<BR>> $check_zin="";<BR>> }<BR>> else if ($zoom_factor<0)<BR>> {<BR>> $check_pan="";<BR>> $check_zout="CHECKED";<BR>> $check_zin="";<BR>> }<BR>> else<BR>> {<BR>> $check_pan="";<BR>> $check_zout="";<BR>> $check_zin="CHECKED";<BR>> }<BR>> $Val_zsize=abs($zoom_factor);<BR>> $map->zoompoint ($zoom_factor, $my_point, $map->width,
$map-<BR>> >height, $my_extent);<BR>> $image = $map->draw();<BR>> $image_url=$image->saveWebImage();<BR>> $extent_to_html = $map->EXTENT->minx." ".$map->EXTENT->miny." <BR>> ".$map->EXTENT->maxx." ".$map->EXTENT->maxy;<BR>> ?><BR>> Could trace anything wrong with my zoom and pan code. SPecifically <BR>> this code<BR>> $map-<BR>> >setextent($extent_to_set[0],$extent_to_set[1],$extent_to_set[2],$extent_to_set[3]);and <BR>> $extent_to_html = $map->EXTENT->minx." ".$map->EXTENT->miny." <BR>> ".$map->EXTENT->maxx." ".$map->EXTENT->maxy;<BR>> as seem to be source of all the above errors<BR>> Muchemi<BR>> <BR>> <BR>> ---------------------------------<BR>> Do you Yahoo!?<BR>> Friends. Fun. Try the all-new Yahoo! Messenger<BR>
<BLOCKQUOTE></BLOCKQUOTE>
<DIV></DIV></TD></FORM></TR></TBODY></BLOCKQUOTE><p>
<hr size=1><font face=arial size=-1>Do you Yahoo!?<br>Friends. Fun. <a href="http://messenger.yahoo.com/">Try the all-new Yahoo! Messenger</a>
--0-2129600517-1085992655=:28075--
