[Mapserver-users] Setup errors
Andrew Rich
devel at itdownunder.com.au
Sun May 30 09:44:53 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_002E_01C446A0.1B9E7E20
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hello all
I am setting up Mapserver for the first time and require some help when
I have trouble.
At the moment I believe Mapserv is compiling ok but one of the
dependencies has a problem.
Linux Platform (RH 7.3)
GD 2.0.22
Freetype 1.3.1
Jpeg-6b
Libpng 1.2.5
Mapserver 4.2
Proj 4.4.7
Xpm-3.4k
Zlib 1.2.1
When running the demo site I receive the following error in the HTTPD
(Apache 1.3.27) log:
libpng warning: Application was compiled with png.h from libpng-1.2.5
libpng warning: Application is running with png.c from libpng-1.0.14
gd-png: fatal libpng error: Incompatible libpng version in application
and library
[Sun May 30 23:27:51 2004] [error] [client 203.217.43.110] Premature end
of script headers: /var/www/cgi-bin/mapserv
Initially I had these but recompiled Libpng-1.2.5 and then fixed a
libpng12.so.0 dependancy not found problem:
The /usr/local/lib contains the following:
[root at tanami src]# ls -al /usr/local/lib/libpng*
-rw-r--r-- 1 root root 162990 May 30 22:23
/usr/local/lib/libpng12.a
lrwxrwxrwx 1 root root 13 May 30 22:23
/usr/local/lib/libpng12.so -> libpng12.so.0
lrwxrwxrwx 1 root root 19 May 30 22:23
/usr/local/lib/libpng12.so.0 -> libpng12.so.0.1.2.5
-rwxr-xr-x 1 root root 196402 May 30 22:23
/usr/local/lib/libpng12.so.0.1.2.5
lrwxrwxrwx 1 root root 10 May 30 22:23
/usr/local/lib/libpng.a -> libpng12.a
lrwxrwxrwx 1 root root 11 May 30 22:23
/usr/local/lib/libpng.so -> libpng.so.3
lrwxrwxrwx 1 root root 11 May 30 22:25
/usr/local/lib/libpng.so.2 -> libpng.so.3
lrwxrwxrwx 1 root root 17 May 30 22:23
/usr/local/lib/libpng.so.3 -> libpng.so.3.1.2.5
/usr/local/lib/libpng.so.3.1.2.5
A ldd mapserv gives the following result:
[root at tanami src]# ldd /var/www/cgi-bin/mapserv
libgd.so.2 => /usr/local/lib/libgd.so.2 (0x4002b000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40064000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40082000)
libpng.so.2 => /usr/lib/libpng.so.2 (0x400c1000)
libz.so.1 => /usr/lib/libz.so.1 (0x400e3000)
libtiff.so.3 => /usr/lib/libtiff.so.3 (0x400f1000)
libm.so.6 => /lib/i686/libm.so.6 (0x40134000)
libc.so.6 => /lib/i686/libc.so.6 (0x42000000)
libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x40157000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40165000)
libpng12.so.0 => /usr/local/lib/libpng12.so.0 (0x4023a000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
libdl.so.2 => /lib/libdl.so.2 (0x40267000)
A locate on png.h: (I removed .html files from paste)
[root at tanami src]# locate png.h
/usr/lib/interchange-4.9.9/foundation/pages/survey/graph.png.html
/usr/lib/interchange-4.9.8-200309280658/dist/foundation/pages/survey/gra
ph.png.html
/usr/include/mozilla-1.0.2/png/png.h
/usr/include/png.h.old
/usr/local/include/libpng/png.h
/usr/local/include/png.h
/usr/src/libpng-1.2.5/contrib/gregbook/readpng.h
/usr/src/libpng-1.2.5/contrib/gregbook/writepng.h
/usr/src/libpng-1.2.5/png.h
A locate on png.c:
[root at tanami src]# locate png.c
/usr/src/gd-2.0.22/gd_png.c
/usr/src/gd-2.0.22/gd2topng.c
/usr/src/gd-2.0.22/gdparttopng.c
/usr/src/gd-2.0.22/gdtopng.c
/usr/src/gd-2.0.22/webpng.c
/usr/src/libpng-1.2.5/contrib/gregbook/readpng.c
/usr/src/libpng-1.2.5/contrib/gregbook/wpng.c
/usr/src/libpng-1.2.5/contrib/gregbook/writepng.c
/usr/src/libpng-1.2.5/contrib/pngminus/pnm2png.c
/usr/src/libpng-1.2.5/png.c
/usr/src/libpng-1.2.5/projects/borland/libpng.cpp
So can someone please give me an idea what to look for next.
Thank you
Andrew Rich
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C446A0.1ACEAB00">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"time"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.EmailStyle18
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hello all<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I am setting up Mapserver for the first time and =
require
some help when I have trouble.<o:p></o:p></span></font></p>
font-family:Arial'>At the moment I believe Mapserv is compiling ok but =
one of
the dependencies has a problem.<o:p></o:p></span></font></p>
font-family:Arial'>Linux Platform (RH 7.3)<o:p></o:p></span></font></p>
font-family:Arial'>GD 2.0.22<o:p></o:p></span></font></p>
font-family:Arial'>Freetype 1.3.1<o:p></o:p></span></font></p>
font-family:Arial'>Jpeg-6b<o:p></o:p></span></font></p>
font-family:Arial'>Libpng 1.2.5<o:p></o:p></span></font></p>
font-family:Arial'>Mapserver 4.2<o:p></o:p></span></font></p>
font-family:Arial'>Proj 4.4.7<o:p></o:p></span></font></p>
font-family:Arial'>Xpm-3.4k<o:p></o:p></span></font></p>
font-family:Arial'>Zlib 1.2.1<o:p></o:p></span></font></p>
font-family:Arial'>When running the demo site I receive the following =
error in
the HTTPD (Apache 1.3.27) log:<o:p></o:p></span></font></p>
font-family:Arial'>libpng warning: Application was compiled with png.h =
from
libpng-1.2.5<o:p></o:p></span></font></p>
font-family:Arial'>libpng warning: Application<span
style=3D'mso-spacerun:yes'> </span>is<span =
</span>running with png.c from =
libpng-1.0.14<o:p></o:p></span></font></p>
font-family:Arial'>gd-png:<span style=3D'mso-spacerun:yes'> =
</span>fatal
libpng error: Incompatible libpng version in application and =
library<o:p></o:p></span></font></p>
font-family:Arial'>[Sun May 30 </span></font><st1:time Hour=3D"23" =
Minute=3D"27"><font
style=3D'font-size:10.0pt;font-family:Arial'>23:27:51</span></font></st1:=
time><font
style=3D'font-size:10.0pt;font-family:Arial'> 2004]
[error] [client 203.217.43.110] Premature end of script headers:
/var/www/cgi-bin/mapserv<o:p></o:p></span></font></p>
font-family:Arial'>Initially I had these but recompiled Libpng-1.2.5 and =
then
fixed a libpng12.so.0 dependancy not found problem:<span
style=3D'mso-spacerun:yes'> </span><o:p></o:p></span></font></p>
font-family:Arial'>The /usr/local/lib contains the =
following:<o:p></o:p></span></font></p>
font-family:Arial'>[root at tanami src]# ls -al =
/usr/local/lib/libpng*<o:p></o:p></span></font></p>
font-family:Arial'>-rw-r--r--<span =
</span>1 root<span style=3D'mso-spacerun:yes'>
</span>root<span =
</span>162990 May 30 </span></font><st1:time Hour=3D"22" =
Minute=3D"23"><font
style=3D'font-size:10.0pt;font-family:Arial'>22:23</span></font></st1:tim=
e><font
/usr/local/lib/libpng12.a<o:p></o:p></span></font></p>
font-family:Arial'>lrwxrwxrwx<span =
</span>root<span
style=3D'mso-spacerun:yes'> &nbs=
p;
</span>13 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font =
size=3D2
e><font
/usr/local/lib/libpng12.so -> =
libpng12.so.0<o:p></o:p></span></font></p>
</span>root<span
p;
</span>19 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font =
size=3D2
e><font
/usr/local/lib/libpng12.so.0 -> =
libpng12.so.0.1.2.5<o:p></o:p></span></font></p>
font-family:Arial'>-rwxr-xr-x<span =
</span>root<span =
</span>196402 May 30 </span></font><st1:time Hour=3D"22" =
Minute=3D"23"><font
e><font
/usr/local/lib/libpng12.so.0.1.2.5<o:p></o:p></span></font></p>
</span>root<span
p;
</span>10 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font =
size=3D2
e><font
style=3D'font-size:10.0pt;font-family:Arial'> /usr/local/lib/libpng.a
-> libpng12.a<o:p></o:p></span></font></p>
</span>root<span
p;
</span>11 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font =
size=3D2
e><font
/usr/local/lib/libpng.so -> libpng.so.3<o:p></o:p></span></font></p>
</span>root<span
p;
</span>11 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"25"><font =
size=3D2
style=3D'font-size:10.0pt;font-family:Arial'>22:25</span></font></st1:tim=
e><font
/usr/local/lib/libpng.so.2 -> =
</span>root<span =
</span><span =
style=3D'mso-spacerun:yes'> </span>17
May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font size=3D2 =
face=3DArial><span
e><font
/usr/local/lib/libpng.so.3 -> =
libpng.so.3.1.2.5<o:p></o:p></span></font></p>
</span>root<span =
Minute=3D"23"><font
e><font
/usr/local/lib/libpng.so.3.1.2.5<o:p></o:p></span></font></p>
font-family:Arial'>A ldd mapserv gives the following =
result:<o:p></o:p></span></font></p>
font-family:Arial'>[root at tanami src]# ldd =
font-family:Arial'><span
</span><span
style=3D'mso-spacerun:yes'> </span>libgd.so.2 =3D>
/usr/local/lib/libgd.so.2 (0x4002b000)<o:p></o:p></span></font></p>
</span>libjpeg.so.62 =3D> /usr/lib/libjpeg.so.62 =
(0x40064000)<o:p></o:p></span></font></p>
</span>libfreetype.so.6 =3D> /usr/lib/libfreetype.so.6 =
(0x40082000)<o:p></o:p></span></font></p>
</span>libpng.so.2 =3D> /usr/lib/libpng.so.2 =
(0x400c1000)<o:p></o:p></span></font></p>
</span>libz.so.1 =3D> /usr/lib/libz.so.1 =
(0x400e3000)<o:p></o:p></span></font></p>
</span>libtiff.so.3 =3D> /usr/lib/libtiff.so.3 =
(0x400f1000)<o:p></o:p></span></font></p>
</span>libm.so.6 =3D> /lib/i686/libm.so.6 =
(0x40134000)<o:p></o:p></span></font></p>
</span>libc.so.6 =3D> /lib/i686/libc.so.6 =
(0x42000000)<o:p></o:p></span></font></p>
</span>libXpm.so.4 =3D> /usr/X11R6/lib/libXpm.so.4 =
(0x40157000)<o:p></o:p></span></font></p>
</span>libX11.so.6 =3D> /usr/X11R6/lib/libX11.so.6 =
(0x40165000)<o:p></o:p></span></font></p>
</span>libpng12.so.0 =3D> /usr/local/lib/libpng12.so.0 =
(0x4023a000)<o:p></o:p></span></font></p>
</span>/lib/ld-linux.so.2 =3D> /lib/ld-linux.so.2 =
(0x40000000)<o:p></o:p></span></font></p>
</span>libdl.so.2 =3D> /lib/libdl.so.2 =
(0x40267000)<o:p></o:p></span></font></p>
font-family:Arial'>A locate on png.h: (I removed .html files from =
paste)<o:p></o:p></span></font></p>
font-family:Arial'>[root at tanami src]# locate =
png.h<o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/interchange-4.9.9/foundation/pages/survey/gra=
ph.png.html<o:p></o:p></span></font></p>
font-family:Arial'>/usr/lib/interchange-4.9.8-200309280658/dist/foundatio=
n/pages/survey/graph.png.html<o:p></o:p></span></font></p>
font-family:Arial'>/usr/include/mozilla-1.0.2/png/png.h<o:p></o:p></span>=
</font></p>
font-family:Arial'>/usr/include/png.h.old<o:p></o:p></span></font></p>
font-family:Arial'>/usr/local/include/libpng/png.h<o:p></o:p></span></fon=
t></p>
font-family:Arial'>/usr/local/include/png.h<o:p></o:p></span></font></p>
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/readpng.h<o:p><=
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/writepng.h<o:p>=
font-family:Arial'>/usr/src/libpng-1.2.5/png.h<o:p></o:p></span></font></=
p>
font-family:Arial'>A locate on png.c:<o:p></o:p></span></font></p>
png.c<o:p></o:p></span></font></p>
font-family:Arial'>/usr/src/gd-2.0.22/gd_png.c<o:p></o:p></span></font></=
p>
font-family:Arial'>/usr/src/gd-2.0.22/gd2topng.c<o:p></o:p></span></font>=
</p>
font-family:Arial'>/usr/src/gd-2.0.22/gdparttopng.c<o:p></o:p></span></fo=
nt></p>
font-family:Arial'>/usr/src/gd-2.0.22/gdtopng.c<o:p></o:p></span></font><=
/p>
font-family:Arial'>/usr/src/gd-2.0.22/webpng.c<o:p></o:p></span></font></=
p>
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/readpng.c<o:p><=
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/wpng.c<o:p></o:=
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/gregbook/writepng.c<o:p>=
font-family:Arial'>/usr/src/libpng-1.2.5/contrib/pngminus/pnm2png.c<o:p><=
font-family:Arial'>/usr/src/libpng-1.2.5/png.c<o:p></o:p></span></font></=
p>
font-family:Arial'>/usr/src/libpng-1.2.5/projects/borland/libpng.cpp<o:p>=
font-family:Arial'>So can someone please give me an idea what to look =
for next.<o:p></o:p></span></font></p>
font-family:Arial'>Thank you<o:p></o:p></span></font></p>
font-family:Arial'>Andrew Rich<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_002E_01C446A0.1B9E7E20--
