[Mapserver-users] mscalculate() and explode()
AARON KONING
aaronkoning at shaw.ca
Mon May 31 12:45:27 EDT 2004
I would echo out the $extent_to_set[0]ie: floating point numbers at appropriate sizes) prior to $map->setextent.
eg:
print_r($extent_to_set);
die();
Aaron
----- Original Message -----
Date: Monday, May 31, 2004 1:37 am
Subject: Re: [Mapserver-users] mscalculate() and explode()
> Yes the array explode has worked as per your instructions
> Could also somebody sought me out on this next error on the same
> coding
> Fatal error: [MapServer Error]: msCalculateScale(): Invalid image
> extent. in C:\Program Files\Apache
> Group\Apache2\htdocs\Nakmap\nakint.php on line 19
> AARON KONING <aaronkoning at shaw.ca> wrote:
> The PHP function 'explode' requires two arguments and you have only
> provided one. Change the explode function on line 18 to include the
> two arguments as per below.
> Function definition from php.net:
> array explode ( string separator, string string [, int limit])
> Aaron
> From: julius muchemi
> Date: Saturday, May 29, 2004 5:57 am
> Subject: [Mapserver-users] mscalculate() and explode()
> > i have ahead with the project and after displaying the the layer
> > now want to add zoom and pan capabilities to the previous code.
> > I'm still on windows 2000.
> > i have the following error in browser which i dont know how to
> > solve
> > Warning: Wrong parameter count for explode() in C:\Program
> > Files\Apache Group\Apache2\htdocs\Nakmap\nakint.php on line 18
> > The code looks like this:
> > ?php
> > dl("php_mapscript_4.0.1.dll");
> > $map_path = "C:/Program Files/Apache Group/Apache2/htdocs/Nakmap/";
> > $map = ms_newMapObj($map_path."nakuru.map");
> > $val_zsize=3;
> > $check_pan="CHECKED";
> > " MEHOD="POST">
> > $extent_to_set=explode("EXTENT");
> > $map-
> >setextent($extent_to_set[0],$extent_to_set[1],$extent_to_set[2],$extent_to_set[3]);$my_extent=ms_newpointObj();> $my_point->setXY("mapa_x", "mapa_y");
> > $my_extent = ms_newrectObj();
> > $my_extent = $map->setextent($extent_to_set[0],
> $extent_to_set[1],
> > $extent_to_set[2], $extent_to_set[3]);
> > > $zoom_factor=("zoom")*("zsize");
> > if ($zoom_factor==0)
> > $zoom_factor=1;
> > $CHECK_zout="";
> > $check_zin="";
> > else if ($zoom_factor<0)
> > $check_pan="";
> > $check_zout="CHECKED";
> > $check_zin="";
> > else
> > $check_pan="";
> > $check_zout="";
> > $check_zin="CHECKED";
> > $Val_zsize=abs($zoom_factor);
> > $map->zoompoint ($zoom_factor, $my_point, $map->width, $map-
> > >height, $my_extent);
> > $image = $map->draw();
> > $image_url=$image->saveWebImage();
> > $extent_to_html = $map->EXTENT->minx." ".$map->EXTENT->miny."
> > ".$map->EXTENT->maxx." ".$map->EXTENT->maxy;
> > Could trace anything wrong with my zoom and pan code.
> SPecifically
> > this code
> > $map-
> >setextent($extent_to_set[0],$extent_to_set[1],$extent_to_set[2],$extent_to_set[3]);and
> > as seem to be source of all the above errors
> > Muchemi
> > Do you Yahoo!?
> > Friends. Fun. Try the all-new Yahoo! Messenger
> Do you Yahoo!?
