[Mapserver-users] bug postgis query alias
Vladimir Guzmán
bigfoot at main-task.com
Mon May 31 16:29:45 EDT 2004
Hello.
I'm implementing a gps tracking system.
I want to show the car's orientation like this:
http://maintask.com/test.png
The layer's data is something like this:
gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
rumbo,velocidad,gps_geom,oid from gps_vehi where tiempo>='2004-05-29
05:00:00' and tiempo<='2004-05-30 04:59:59') as foo using unique gid
using srid=1
The field 'sentido' contains '>'.
The problem is that if I use something like this:
gps_geom from (select gid,'>' as sentido,tiempo,360-rumbo+90 as
using srid=1
The query doesn't work.
So I had to create a column in potgres called 'sentido' and all the rows
containing '>'.
Is this a bug?
The rest of the layer:
LAYER
NAME "puntosgps"
CONNECTIONTYPE postgis
CONNECTION "user=gps password=gps dbname=gps host=localhost"
DATA "gps_geom from (select gid,sentido,tiempo,360-rumbo+90 as
using srid=1"
TYPE POINT
PROJECTION
"proj=latlong"
"datum=WGS84"
END
LABELANGLEITEM 'rumbo'
LABELITEM 'sentido'
CLASS
NAME 'Parado'
EXPRESSION ([velocidad] = 0)
SIZE 14
SYMBOL 'circle'
COLOR 0 0 215
OUTLINECOLOR 204 204 204
END
CLASS
NAME '0-10'
EXPRESSION ([velocidad] > 0 AND[velocidad] <= 10)
SIZE 14
SYMBOL 'circle'
COLOR 255 255 204
LABEL
TYPE TRUETYPE
FORCE TRUE
FONT arial
ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 255 255 255
SIZE 8
END
END
Thanks a lot.
Vladimir Ilich Guzmán R.
http://maintask.com
