text/html and application/x-pdf FORMATS and WMS
GetLegendGraphic and WMS GetCapabilities
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Nov 4 12:46:55 EST 2004
I have entered a couple of bugs related to your e-mail :
- pdf support for GetLegendGraphic with application/x-pdf (Bug 1028)
- swf support for GetLegendGraphic with application/x-shockwave-flash
(Bug 1029)
- limits for GetLegendGraphic with RULE for GD outputformat only (Bug
1030)
I am not sure if these will be adressed for the 4.4 release since the
most widly use format for WMS are GD type formats. I guess for now the
only critical thing is to expose supported formats in the capabilities.
There is already a bug in mapserver (bug 455) adressing this issue that
is on the hit list before 4.4 release.
Later,
Havard Tveite wrote:
> For the "application/x-pdf" and "text/html" FORMATs
> reported by a WMS 1.1.1 GetCapabilities response for
> GetLegendGraphic I am experiencing problems when
> using GetLegendGraphic.
> A GetCapabilities request to my Mapserver WMS server returns:
> <GetLegendGraphic>
> <Format>image/jpeg</Format>
> <Format>image/png</Format>
> <Format>image/gif</Format>
> <Format>image/wbmp</Format>
> <Format>text/html</Format>
> <Format>application/x-pdf</Format>
> <Format>image/tiff</Format>
> <DCPType>
> </DCPType>
> </GetLegendGraphic>
> For all formats except "application/x-pdf" and "text/html"
> a nice legend (graphics and text) is returned.
> For the following requests (equal to the successful ones,
> except for the FORMAT), mapserver crashes ("premature end
> of script headers: mapserv" in the Apache log):
> ...&service=WMS&version=1.1.1&request=GetLegendGraphic&layer=n5000arf&SCALE=200000&FORMAT=image/gif
> ...&service=WMS&version=1.1.1&request=GetLegendGraphic&layer=n5000arf&SCALE=200000&FORMAT=application/x-pdf
> When I use a RULE (to get only the graphics), the following is
> returned
> <ServiceExceptionReport version="1.1.1">
> <ServiceException code="InvalidRule">
> msWMSGetLegendGraphic(): Image handling error. Unavailable RULE
> (Skog). msCreateLegendIcon(): GD library error. Map outputformat must be
> set to a GD format!
> </ServiceException>
> </ServiceExceptionReport>
> MapServer version 4.4.0-beta1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=SDE
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> Is it a problem in my setup or a bug?
> If it is a bug, the output from GetCapabilities should to be changed.
> Håvard Tveite
> IMT, NLH
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
