WFS map file
    Bart van den Eijnden
    bartvde at XS4ALL.NL
    Fri Nov  5 10:00:42 PST 2004
could you explain what you mean exactly with the following sentence:
"However, only the layer name can be showed as WFS not the real layer map."
And which requests are you trying against your WFS, or how are you trying
to visualize your data?
Best regards,
Bart
On Fri, 5 Nov 2004 11:41:32 -0600, N Zhou <zhou_naijun at HOTMAIL.COM> wrote:
> Hi,
> I'm new to the WFS. I have a working WMS map file, and I followed the
> HOW To
> instruction to modify the WMS map file to WFS. However, only the layer
> name
> can be showed as WFS not the real layer map. Is this because of map
> projection: the data are in a projection currently not supported in
> EPSG? Or
> I have errors in the map file?
> Thank you very much!
> My map file is:
> Map
>   NAME "MyServices"
>   STATUS ON
>   EXTENT 177185 124886 891620 939320
>   SIZE 400 400
>   UNITS METERS
>   # Start of web interface definition
>   WEB
>     MINSCALE 1
>     MAXSCALE 10000000
>     METADATA
>       "wfs_title"  "DNRServices"
>       "wfs_srs"  "EPSG:90000"
>       "wfs_onlineresource"
> "http://myhost/cgi-bin/mapserv?map=thismapfile.map"
>     END
>   END
>   PROJECTION
>     "init=epsg:90000"
>   END
> # Start of layer definitions
>      LAYER
>      NAME "water"
>      STATUS ON
>      DATA "hydppoly"
>      TYPE  POLYGON
>           CLASSITEM 'HYDNW92M_'
>           MINSCALE 400000
>           PROJECTION
>             "init=epsg:90000"
>      END
>      DUMP TRUE
>      METADATA
>        "wfs_title"  "Open Water"
>      END
>      CLASS
>         EXPRESSION /./
>         STYLE
>            COLOR -1 -1 -1
>            OUTLINECOLOR 0 0 255
>            SIZE 1
>            SYMBOL 0
>         END
>      END
>   END
> END
> N. Zhou
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
More information about the MapServer-users
