WFS map file
N Zhou
zhou_naijun at HOTMAIL.COM
Fri Nov 5 13:21:04 EST 2004
I'm using the Itasca demo provided as a demo of mapserver.
I can get layer names defined in the WFS map file, but the layer is not
showed in a map window when I click a layer name. This worked
in the WMS map file.
Thank you!
N. Zhou
>could you explain what you mean exactly with the following sentence:
>"However, only the layer name can be showed as WFS not the real layer map."
>And which requests are you trying against your WFS, or how are you trying
>to visualize your data?
>Best regards,
>Bart
>On Fri, 5 Nov 2004 11:41:32 -0600, N Zhou <zhou_naijun at HOTMAIL.COM> wrote:
>>Hi,
>>I'm new to the WFS. I have a working WMS map file, and I followed the HOW
>>To
>>instruction to modify the WMS map file to WFS. However, only the layer
>>name
>>can be showed as WFS not the real layer map. Is this because of map
>>projection: the data are in a projection currently not supported in EPSG?
>>Or
>>I have errors in the map file?
>>Thank you very much!
>>My map file is:
>>Map
>> NAME "MyServices"
>> STATUS ON
>> EXTENT 177185 124886 891620 939320
>> SIZE 400 400
>> UNITS METERS
>> # Start of web interface definition
>> WEB
>> MINSCALE 1
>> MAXSCALE 10000000
>> METADATA
>> "wfs_title" "DNRServices"
>> "wfs_srs" "EPSG:90000"
>> "wfs_onlineresource"
>>"http://myhost/cgi-bin/mapserv?map=thismapfile.map"
>> END
>> END
>> PROJECTION
>> "init=epsg:90000"
>> END
>># Start of layer definitions
>> LAYER
>> NAME "water"
>> STATUS ON
>> DATA "hydppoly"
>> TYPE POLYGON
>> CLASSITEM 'HYDNW92M_'
>> MINSCALE 400000
>> PROJECTION
>> "init=epsg:90000"
>> END
>> DUMP TRUE
>> METADATA
>> "wfs_title" "Open Water"
>> END
>> CLASS
>> EXPRESSION /./
>> STYLE
>> COLOR -1 -1 -1
>> OUTLINECOLOR 0 0 255
>> SIZE 1
>> SYMBOL 0
>> END
>> END
>> END
>>END
>>N. Zhou
>Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
