WFS map file
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Nov 5 13:29:52 EST 2004
AFAIK the Itasca demo uses the native Mapserver interface (mode=map etc.),
and is not a WFS client (nor WMS client).
I don't see anything wrong with your MAP file at first sight, but maybe
someone else does ... are there any error messages in an error log?
Best regards,
Bart
On Fri, 5 Nov 2004 12:21:04 -0600, N Zhou <zhou_naijun at HOTMAIL.COM> wrote:
> I'm using the Itasca demo provided as a demo of mapserver.
> I can get layer names defined in the WFS map file, but the layer is not
> showed in a map window when I click a layer name. This worked
> in the WMS map file.
> Thank you!
> N. Zhou
>> could you explain what you mean exactly with the following sentence:
>> "However, only the layer name can be showed as WFS not the real layer
>> map."
>> And which requests are you trying against your WFS, or how are you
>> trying
>> to visualize your data?
>> Best regards,
>> Bart
>> On Fri, 5 Nov 2004 11:41:32 -0600, N Zhou <zhou_naijun at HOTMAIL.COM>
>> wrote:
>>> Hi,
>>> I'm new to the WFS. I have a working WMS map file, and I followed the
>>> HOW
>>> To
>>> instruction to modify the WMS map file to WFS. However, only the layer
>>> name
>>> can be showed as WFS not the real layer map. Is this because of map
>>> projection: the data are in a projection currently not supported in
>>> EPSG?
>>> Or
>>> I have errors in the map file?
>>> Thank you very much!
>>> My map file is:
>>> Map
>>> NAME "MyServices"
>>> STATUS ON
>>> EXTENT 177185 124886 891620 939320
>>> SIZE 400 400
>>> UNITS METERS
>>> # Start of web interface definition
>>> WEB
>>> MINSCALE 1
>>> MAXSCALE 10000000
>>> METADATA
>>> "wfs_title" "DNRServices"
>>> "wfs_srs" "EPSG:90000"
>>> "wfs_onlineresource"
>>> "http://myhost/cgi-bin/mapserv?map=thismapfile.map"
>>> END
>>> END
>>> PROJECTION
>>> "init=epsg:90000"
>>> END
>>> # Start of layer definitions
>>> LAYER
>>> NAME "water"
>>> STATUS ON
>>> DATA "hydppoly"
>>> TYPE POLYGON
>>> CLASSITEM 'HYDNW92M_'
>>> MINSCALE 400000
>>> PROJECTION
>>> "init=epsg:90000"
>>> END
>>> DUMP TRUE
>>> METADATA
>>> "wfs_title" "Open Water"
>>> END
>>> CLASS
>>> EXPRESSION /./
>>> STYLE
>>> COLOR -1 -1 -1
>>> OUTLINECOLOR 0 0 255
>>> SIZE 1
>>> SYMBOL 0
>>> END
>>> END
>>> END
>>> END
>>> N. Zhou
>> Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
