workshop error
R. Paul Warriner
paul at WARRINER.US
Fri Nov 5 20:02:37 EST 2004
Thanks Steve
---- Original message ----
>Date: Fri, 5 Nov 2004 17:27:15 -0600
>From: Steve Lime
<steve.lime at DNR.STATE.MN.US>
>Subject: Re: [UMN_MAPSERVER-USERS]
workshop error
>To: MAPSERVER-USERS at lists.umn.edu
>Note that I've fixed the workshop site
at the DNR and have rebuilt the
>zip file. Problem should be fixed now.
>Steve
>>>> Frank Warmerdam
<warmerdam at POBOX.COM> 11/4/2004 7:27:49
PM >>>
>R. Paul Warriner wrote:
>> Hello Ethan,
>> Interesting, keeping in mind I am
>> novice, I commented out the second NAME
>> instance, and voila; it worked.
>> Funny, 4.2 didn't care, but 4.4 does.
>> It is the workshop - itasca.map file,
>> with the 3rd line "NAME cities":
>> LAYER
>> NAME mcd90py2_anno
>> NAME cities
>> TYPE ANNOTATION
>> DATA mcd90py2
>> STATUS OFF
>> LABELITEM "city_name"
>> CLASSITEM "city_name"
>> LABELMAXSCALE 500000
>> CLASS
>> EXPRESSION /./
>> LABEL
>> COLOR 0 0 0
>> SHADOWCOLOR 218 218 218
>> SHADOWSIZE 2 2
>> TYPE BITMAP
>> SIZE MEDIUM
>> POSITION CC
>> PARTIALS FALSE
>> BUFFER 2
>> END
>> END
>Paul,
>Sean pointed out that there was a bug
fix related to this. In 4.4 we
>try
>to error out on multiple defined values
for stuff like NAME. It is an
>improvement ... really! In the past
the first name was ignored and
>the
>second was used but if the second was
far down in a complex layer
>definition
>it would be easy to miss it and not
know why referring to the layer by
>it's
>first name didn't work.
>Best regards,
>I set the clouds in motion - turn up
| Frank Warmerdam,
>warmerdam at pobox.com
>light and sound - activate the windows
| http://pobox.com/~warmerdam
>and watch the world go round - Rush
| Geospatial Programmer for
>Rent
