PHP mapscript module not found
Tom Price
tom_price at YAHOO.COM
Mon Nov 8 18:57:12 EST 2004
I am in the process of upgrading PHP from 4.2.1 to 4.3.7.
Mapscript 3.6.2 seems to have a problem with this version of PHP
(getting message about "php_mapscript cannot be used as a 'cgi-fcgi'
module") even though PHP is installed as a CGI.
So then upgraded Mapscript to 4.3 and started getting this message
instead:
Warning: Unable to load dynamic library './php_mapscript_43.dll' - The
specified module could not be found.
Message appears if module is enabled in php.ini or if loaded using a
"dl" command.
The php_mapscript_43.dll file is in same folder with php.exe and
extension_dir is set to "./" in php.ini. (No change from 3.6.2)
Adding php folder to the path did not seem to make any difference.
Running IIS/PWS 5 on Windows 2000 Pro SP4.
Any help, most appreciated!
__________________________________
Do you Yahoo!?
Check out the new Yahoo! Front Page.
www.yahoo.com
