PHP mapscript module not found
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Nov 9 02:15:47 EST 2004
did you put all the dependent dll's for mapscript (like gdal12.dll etc.)
in your path?
Best regards,
Bart
> I am in the process of upgrading PHP from 4.2.1 to 4.3.7.
> Mapscript 3.6.2 seems to have a problem with this version of PHP
> (getting message about "php_mapscript cannot be used as a 'cgi-fcgi'
> module") even though PHP is installed as a CGI.
> So then upgraded Mapscript to 4.3 and started getting this message
> instead:
> Warning: Unable to load dynamic library './php_mapscript_43.dll' - The
> specified module could not be found.
> Message appears if module is enabled in php.ini or if loaded using a
> "dl" command.
> The php_mapscript_43.dll file is in same folder with php.exe and
> extension_dir is set to "./" in php.ini. (No change from 3.6.2)
> Adding php folder to the path did not seem to make any difference.
> Running IIS/PWS 5 on Windows 2000 Pro SP4.
> Any help, most appreciated!
> __________________________________
> Do you Yahoo!?
> Check out the new Yahoo! Front Page.
> www.yahoo.com
