Return of IMSEMU
Paul Ramsey
pramsey at REFRACTIONS.NET
Tue Nov 9 13:25:49 EST 2004
Probably not, but that should be simple enough to add. Might need to do
some extra bindings in mapscript for ESRI-WKT parsing though. Howard did
this already in PyIMS, but the binding is in python to ogr, not in
mapscript. If one is willing to accept a few failure cases in the short
term for those WKT examples where ESRI is notably non-standard the
existing projectionfromwkt binding should work fine.
P.
Ed McNierney wrote:
> Paul -
> Great! Have you used this with ArcGIS 9 / Service Pack 1? I've been
> trying to get OUR PHP/MapScript code out to the group, but just when
> I thought we were ready, Service Pack 1 came along and broke
> everything. SP1 switched to using ESRI-flavored WKT projection
> definitions instead of EPSG codes, and I have not had the time yet to
> deal with it.
> - Ed
> Ed McNierney President and Chief Mapmaker TopoZone.com / Maps a la
> carte, Inc. 73 Princeton Street, Suite 305 North Chelmsford, MA
> 01863 ed at topozone.com (978) 251-4242
> -----Original Message----- From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Paul Ramsey Sent:
> Tuesday, November 09, 2004 10:42 AM To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Return of IMSEMU
> Hi all, We are pleased to announce a new and improved version of
> IMSEMU for your emulating pleasure. For those new to the concept,
> IMSEMU is a script which wraps around Mapserver and speaks ArcXML to
> client software. This allows ESRI software such as ArcMap and
> ArcExplorer to directly access mapserver services using ArcXML -- no
> special interoperability extensions required. The new version of
> IMSEMU is written using PHP/Mapscript, so the installation should be
> much easier than for the old Perl based version. Assuming you have
> PHP support for Mapscript and DOMXML, just drop the script in the
> right place and go. The new version also adds many features. The
> binary stream format is now partially supported, so many
> feature-based aspects of ArcXML are supported, such as full preview
> mode in ArcCatalog. There are still things missing, but we are
> looking forward to your help in finding the remaining gaps and
> filling them in. You can download IMSEMU from
> http://mapserver.refractions.net Paul
