using shpdump and extents
Frank Warmerdam
warmerdam at POBOX.COM
Wed Nov 10 16:09:25 EST 2004
Joseph Norris wrote:
> Hello,
>>From the output of shpdump how does one determine the extents of the
> le? - thanks.
> #Joseph Norris (Perl - what else is there?/Linux/CGI/Mysql) print @c=map chr
> $_+100,(6,17,15,16,-68,-3,10,11,16,4,1,14,-68,12,1,14,8,-68,4,-3,-1,7,1,14,-
> 68,-26,11,15,1,12,4,-68,-22,11,14,14,5,15,-90);
Joseph,
warmerda at gdal2200[43]% shpdump polygon.shp | more
Shapefile Type: Polygon # of Shapes: 474
File Bounds: ( 471127.188, 4751545.000,0,0)
to ( 489292.312, 4765610.500,0,0)
The file points are the lower left and upper right corners. The above
would translate to a MAP EXTENTS line like:
EXTENTS 471127.188 4751545.000 489292.312 4765610.500
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
