SLD filter with raster layers
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Nov 16 15:29:16 EST 2004
Hi Frank,
okay so that's from the 4.2 days, I did not know that. I read it in the
SLD docs on the Wiki.
Btw, is there any new documentation for the SLD part of Mapserver coming
with the 4.4 release, or is the following link still the most current
version?
http://www2.dmsolutions.ca/tmp/Mapserver_SLD.html
Best regards,
Bart
On Tue, 16 Nov 2004 09:53:51 -0500, Frank Warmerdam <warmerdam at POBOX.COM>
wrote:
> Bart van den Eijnden wrote:
>> Hi Berend,
>> is your raster 8 bit? AFAIK it does work but only with 8 bit rasters.
> Bart,
> Note, in MapServer 4.4 the raster classification support should work with
> non-8bit layers as well with a few limitations. The SLD definitions are
> just converted into class definitions internally I believe.
> Berend Veldkamp wrote:
> > Bart,
> > Yes it's an 8 bit geotiff. Would it make any difference if I use
> native
> > tiff support instead of GDAL?
> Well, hopefully it won't get any better to use the native support. If
> it does
> I would want to hear about it!
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
