Performance with oraclespatial using ogr
paul
paul.den.dulk at GEODAN.NL
Thu Nov 18 08:32:01 EST 2004
Hi Merlijn,
You can also make selections with oraclespatial with queries like this:
CONNECTIONTYPE oraclespatial
CONNECTION " a/b at c"
DATA "GEOM, LOCATIE_ID FROM (select * from LOCATIE where LOCATIESOORT_ID =
10)"
Paul.
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, November 18, 2004 9:47 AM
Subject: [UMN_MAPSERVER-USERS] Performance with oraclespatial using ogr
> Hi all,
> I have some oracle layers in my map to which I connect using ogr. I use
> ogr because I also make selections on this layer. Everything performs very
> well until the Oracle table gets too many records. As soon as it has more
> than 10,000 records it can take up to a few minutes to make the map.
> Selecting a polygon from this layer takes even more time and selecting n
> polygons can take more than 5 minutes.
> My data parameter is looks like this.
> CONNECTIONTYPE ogr
> CONNECTION "oci: a/b at c"
> DATA "SELECT GEOM, LOCATIE_ID FROM LOCATIE where LOCATIESOORT_ID = 10"
> Is there anyway I can improve performance changing this query or other
> parameters?
> Thanks,
> Merlijn
