Performance with oraclespatial using ogr
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Nov 18 08:16:02 EST 2004
see:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0404/msg00215.html
in short, only by using DATA "tablename" the bbox is used in the query.
Best regards,
Bart
> Hi all,
> I have some oracle layers in my map to which I connect using ogr. I use
> ogr because I also make selections on this layer. Everything performs very
> well until the Oracle table gets too many records. As soon as it has more
> than 10,000 records it can take up to a few minutes to make the map.
> Selecting a polygon from this layer takes even more time and selecting n
> polygons can take more than 5 minutes.
> My data parameter is looks like this.
> CONNECTIONTYPE ogr
> CONNECTION "oci: a/b at c"
> DATA "SELECT GEOM, LOCATIE_ID FROM LOCATIE where LOCATIESOORT_ID = 10"
> Is there anyway I can improve performance changing this query or other
> parameters?
> Thanks,
> Merlijn
