line with arrows
David Fawcett
David.Fawcett at STATE.MN.US
Fri Nov 19 10:53:48 EST 2004
Joerg or fx,
If this works for you, please post the example in the Symbol Examples
page of the Wiki
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?SymbolExamples
Thanks,
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> fx gamoy <fx.gamoy at MAPXPLORE.COM> 11/19/2004 6:23:42 AM >>>
Hello,
you should use this
SYMBOL
NAME 'test'
TYPE TRUETYPE
FONT 'webdings'
CHARACTER ""
FILLED true
ANTIALIAS true
GAP -25 # the negatation tells MapServer to honor the vector
direction
when computing the angle
END
you need to get a webdings.ttf file in your fonts.txt
exemple of layer
LAYER
NAME 'a line'
TYPE LINE
STATUS ON
CLASS
STYLE
COLOR 0 0 0
SYMBOL "circle"
SIZE 1
END
STYLE
SYMBOL 'test'
COLOR 0 0 0
SIZE 14
END
END
FEATURE
POINTS 10 10 50 100 100 300 300 300 10 490 END
END
END
this works with mapserver 4.0 & up
fx
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, November 19, 2004 1:06 PM
Subject: [UMN_MAPSERVER-USERS] line with arrows
> hello,
> I would like to draw a line with an arrow in it.
> The arrow should always point in the line direction, so if the line
goes
> up 30 degrees or so, the arrow does the same.
> Joerg
