line with arrows
joerg pfeiffer
superbla3000 at GMX.NET
Fri Nov 19 12:10:24 EST 2004
I posted it, under
4. A line with arrows ->->->-:
But I have some problems to display
the '>' correct as ascii or whatever it is.
So at the moment I use:
CHARACTER '&\#62;'# don't use the backslash! (the verdana greater than tag)
hhmmmm.... how do I do this correct?
Joerg
David Fawcett wrote:
> Joerg or fx,
> If this works for you, please post the example in the Symbol Examples
> page of the Wiki
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?SymbolExamples
> Thanks,
> David.
> David J. Fawcett
> MN Office of Environmental Assistance
>>>>fx gamoy <fx.gamoy at MAPXPLORE.COM> 11/19/2004 6:23:42 AM >>>
> Hello,
> you should use this
> SYMBOL
> NAME 'test'
> TYPE TRUETYPE
> FONT 'webdings'
> CHARACTER ""
> FILLED true
> ANTIALIAS true
> GAP -25 # the negatation tells MapServer to honor the vector
> direction
> when computing the angle
> END
> you need to get a webdings.ttf file in your fonts.txt
> exemple of layer
> LAYER
> NAME 'a line'
> TYPE LINE
> STATUS ON
> CLASS
> STYLE
> COLOR 0 0 0
> SYMBOL "circle"
> SIZE 1
> END
> STYLE
> SYMBOL 'test'
> COLOR 0 0 0
> SIZE 14
> END
> END
> FEATURE
> POINTS 10 10 50 100 100 300 300 300 10 490 END
> END
> END
> this works with mapserver 4.0 & up
> fx
> ----- Original Message -----
> From: "joerg pfeiffer" <superbla3000 at GMX.NET>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Friday, November 19, 2004 1:06 PM
> Subject: [UMN_MAPSERVER-USERS] line with arrows
>>hello,
>>I would like to draw a line with an arrow in it.
>>The arrow should always point in the line direction, so if the line
> goes
>>up 30 degrees or so, the arrow does the same.
>>Joerg
