thread support when compiling MS4.4b and libmapscript.so
Sean Gillies
sgillies at FRII.COM
Fri Nov 19 14:08:18 EST 2004
On Nov 19, 2004, at 11:49 AM, Dan Barron wrote:
> Sean,
> I have come back to this threading topic and hope I can put together a
> better question or two on MS 4.4b libmapscript.so thread support.
> Maybe
> this is obvious, but I want to make sure it is clear to me - when
> running
> configure for MS 4.4b compile should the "--with-threads=linkopt"
> option be
> used to enable threading in the resulting mapserv executable? In
> addition,
> when building the libmascript.so and mapscript.jar is threading support
> then built into the native library?
> Thanks,
> Dan
Dan,
Yes, you must configure --with-threads so that unsafe code is locked
properly
and so that errors are confined to individual threads. In the native
library?
You mean libmapscript.so? Yes.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
