problem with postGIS and WMS capabilities if wms_extent not
defined
Bart van den Eijnden
bartvde at XS4ALL.NL
Fri Nov 19 16:20:35 EST 2004
Hi Daniel,
yes, both 4.2 and 4.3 binaries work.
Also GetMap requests work with a 4.3 or 4.2 binary, but the 4.4 beta2
gives an internal server error.
[Fri Nov 19 22:28:34 2004] [error] [client 192.168.3.4] Premature end of
script headers: mapserv.exe
So there seems to be something wrong with the PostGIS support in that one
whenever it needs to go to the database for information. Anybody else
experiencing this, or is it my specific setup?
When will a 4.4 beta3 binary be released on maptools? As we never compile
with PostGIS support unfortunately .... :(
Best regards,
Bart
On Fri, 19 Nov 2004 16:10:23 -0500, Daniel Morissette
<dmorissette at DMSOLUTIONS.CA> wrote:
> Bart van den Eijnden wrote:
>> Hi list,
>> I have a PostGIS layer in my MAP file and I am using the 4.4 beta2
>> windows
>> binary from maptools.org. I am on Windows 2000 server.
>> If I don't define a WMS_EXTENT in the METADATA section of my LAYER, I
>> get
>> a crash of the WMS capabilities (only 4 Kb of normally 5 Kb is sent).
>> If I
>> do define the WMS_EXTENT everything works fine.
> Did this use to work with 4.2? Some work was dont in this area after
> beta2, but I'm not aware of this issue. Perhaps you could also try with
> the latest source from CVS if you can.
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
